how to get in my hatch!!!
Old May 18, 2004 | 05:21 PM
daddy33's Avatar
Car: '85 Camaro
quick question. someone drilled into my rear hatch keylock and took out my system. Well they tore the hole lock and i cant get my key in or try to open it with a screwdriver or anything else. I would try to work with it inside but not sure what to do. I need to get my hatch open so i can do some work on it but need to know how to open it up! if you guys know anyway on how to open up the hatch i would greatly appreciate it. Thanks!!
-Tino
Old May 18, 2004 | 05:50 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Re: how to get in my hatch!!!
-Tino
Well, recently repaired my power latch, so I had the whole system apart...
Does your Camaro have a power pulldown latch, or just a manual? If it's the power one, the whole motor assembly can be undone from the inside. The only problem is (kind of chicken-and-egg) that you need to be able to get the internal trim panels off first, and the screws that hold down that back panel are mounted just under the hatch. IOW, inaccessible if it's closed.
Have you talked to a locksmith about it?
Old May 18, 2004 | 06:03 PM
daddy33's Avatar
Car: '85 Camaro
ok sorry i didnt specify it a little more clearly. Its NOT a power motor hatch. Its a manual one and the sucky thing is that i have a custom box that fits in that hole area and the only way for that thing to come out is to have the hatch open! so its kinda really really hard to get that inside back panel off to get to anything. Im getting frustated and just want to know what i can do before i have to spend an arma and a leg and take to a locksmith or someone else.
Old May 19, 2004 | 11:33 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
You said they drilled out the key cylinder right. Depending on the damage they did, if you look at the very back of the lock there should be a rectangle about 1/4 inch long and even smaller wide, see if you can get a screw driver in there and turn it. Take it by a shop if not, a car shop not a lock smith I bet someone will pop it for free.
Old May 19, 2004 | 12:07 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
WOW, nice form. looks just like my 88 execpt, mine has the form. sticker on the rear and doors, and 5.0 F.I. on the power bulge! Looks like you got a paint job and someone left the badge's off.
Daddy33, stick a small screw driver through the hole they drilled and turn it like a key! That's what the dirty, low life, scum sucking bas***d did when he violated your baby!
Old May 19, 2004 | 12:22 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
WOW, nice form. looks just like my 88 execpt, mine has the form. sticker on the rear and doors, and 5.0 ...
you mean mine, yea its been repainted the hood started to peal. And its a macco job I couldn't see paying more for the stickers than the paint :-) next year it will be getting a 3-4 k paint job when I finally get out of college. Then it will get most of the stickers Im still not sure about the door stickers yet though.
Old May 19, 2004 | 12:29 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
macco or not, it still looks good! The sticker's are your option now!
What's broke on your center light? You can usually find parts in the bone yard. When mine quit working I found the contact plate
where the light get's it's power was broken. $2.00 fixed it!
Old May 19, 2004 | 01:13 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I can't find any with that type of spoiler. But its the plastic painted part that goes around it under the spoiler. One of the sides is broken off, now its summer time Ill hit all the bone yards again and see what i find.
sorry didn't mean to hyjack your thread. let us know if you get it open.
Old May 19, 2004 | 05:40 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
I imagine at this point, any color you find will work huh? You can always paint it!!!!:lala:
Old May 19, 2004 | 05:45 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
well I just planed on primering it and painting it when I did my spoiler or when I redo the whole car. Yea any color will do.
Old May 19, 2004 | 05:50 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Got any extra WS-6 center caps? I've got 3 good one's and one with cracks on the clear cover. I hate it when I clean it!
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
