why it do this all of a sudden?
Car: 89 camaro
Engine: 2.8L V6
dude i got out 2 go 2 autozone lastnight and the outside driver side door handle appears to be not working right. i now have 2 pull it downwards then up 2 open the door from the right portion of the handle. what the f..k happen dog? inspected it and it seems that a ruber peice looks like it may have fallen off. the handle right side can almost be pulled out?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Either the hindge broke or the speed nut on the inside of the door skin that holds the handle to the door fell off.There is also a small plastic retainer on the lever of the handle.This holds the rod that ties the handle to the door latch mechanism.All these you will probably need to remove the door panel to fix/replace.
RedLeader289
May 28, 2019 01:47 PM
