Can a 85mph speedo be calibrated for 145mph?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I currently have the speedometer that says Z28 on it, and goes up to 145mph.
I bought 145mph white halo glow gauge things, but I really don't want to fudge up my speedometer. And a regular 145 is so dang pricey now!
Can I just get an 85mph one and put the overlay on it? How could I re-calibrate it?
Thanks!
Thanks!
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Recalibrating a 85 mph would be more $ then just buying a 145 cluster. Yours -would- work fine as the numbers are in the same places as the normal 145, but the trip reset is in a different spot, along with the trip and odometers are reversed.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Weak. Yah, I'm kinda glad that they won't fit on my gauge, as I might have done it! I haven't seen many of that speedo; I have no idea what they came in either.
Guess I'm off to the classifieds!
BTW, how would you go about calibrating it?
Engine: 5.7L TPI
Axle/Gears: 3.42:1
As far as calibration, it would need to be rewound by a shop that deals with that sort of thing. I have never bothered to look into it too far, but complete clusters are in the 80-150 range.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Yah, I actually pulled the speedo from a parts yard for $20
My car is an 88 Iroc-Z with the LB9 and a T5... but I got the 115
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
145, 1984, 85, 87, body, calabrated, calibrated, calibration, camaro, cluster, fast, fox, mph, speedo, speedometer, tpi, z28
