how much is this worth
Old Jun 6, 2004 | 12:58 AM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
didnt know where to put this so here it goes.
I have a car I might want to sell, but i want to know what to tell people the price is.
85 Camaro Z28 350 Carb engine.....Paint is primer but could use a re primer in some spots.....No louvers on hood.....NO RUST.....not in running condition.....all ready but wont start, think its starter problem....New parts, most never ran but installed on car. car doesnt run do to carb fire. Removed Radio.
Removed Emissions Equipment....Removed A/C....Newly Painted Engine And pullys....car originally had 305 tpi....original tranny and rear in car, Red cloth interior is good condition...all gauges work exept fuel and that happens to alot of camaros....all emblems are there. everything, car just needs to start and paint....stock wheels with brand new futura tires....everything is properly installed....just want to get rid of the project and get a new car....engine ran strong before small carb fire...no posi, open diff...stock 323 gears...t tops...119000 miles on body and tranny and bout 45000 on engine....power steering and power brakes with discs in front and drums on back...solid car, can be an easy project if u dont want to go full resto like alot of projects are....no dents or dings....dual crome exhaust tips power windows and locks and power hatch....all interior lights work...come with car cover.
Mods that have been run on Car.
Engine
Electric Fuel pump
New tires
Edelbrock Cam
new alternator
headers
Ravin Muffler
Holley street dominator intake manifold
Energy suspension bushings
carquest shocks
new starter
new flywheel
summit air cleaner
proform valve covers
Mods that are on the car but never ran before.
Off road y pipe
Cutout
K&N filter
Holley 600cfm vac secondary
equuis gauges
radiator
tranny cooler
mallory distributor
plug wires
spark plugs
flex fan
B&M deep tranny pan
fan spacer
battery
summit chrome radiator overflow tank
new rear tranny seal
Oil and tranny oil
Engine oil dipstick
Intake gaskets
Exhaust gaskets
Summit fuel pressure gauge that hooks up to carb
Tranny filter
whole engine wiring harness
pcv and oil cap grommets
all new hoses
I repeat all these parts are BRAND NEW and never used exept wiring harness and i got that from house of camaro
I will throw in the old carb needs rebuild kit, stock y pipe, cat converter, b&m shift kit, extra engine oil and tranny oil set of sunpro gauges, these things are not installed on car
Car is in houston.....what do you guys think i should offer it for? whats it worth? Pics are in sig
Old Jun 6, 2004 | 11:11 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I'd say the price would go up and you'd get more interest if you get the thing running. If it's really that close to running and it just needs a starter, it would be more than worth it monetarily to replace it and have it running. Otherwise, a buyer won't know what problems they'd be getting themselves into and won't offer much for it.
Old Jun 6, 2004 | 09:36 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Probably between $400-600.
Old Jun 7, 2004 | 01:14 AM
Engine: 350 carb
400-600???? You gotta be kidding me...I spent about 700 bucks for the parts that have never been ran....come on, tell me someone will buy it for 2000
Old Jun 7, 2004 | 12:32 PM
private1i's Avatar
sorry to say friend but your car is just that..... not running. I personally would not pay more than a grand for a car that wasnt running. I understand that you put all this money in it BUT that doesnt change the fact it doesnt run. Go spend 50 on a starter and get it running. Then mabey 2k
Old Jun 7, 2004 | 12:39 PM
Morley's Avatar
Not just no but, HELL no. 2K....I paid $1200 for a 91 formula (1LE) 350 TPI that runs like a raped ape and looked good, just needed a fender.
Non running, butchered (as in converted from TPI which is desireable, to a carb) fair interior, no way to know if transand other parts are ok , no paint....$500 tops..but you know what they say; "there's a sucker born every minute".
If you don't want to spend the time making it a running car, just sell off the parts, you'll likely get more than $500 for them if sold individually.
Old Jun 7, 2004 | 12:53 PM
Engine: 350 carb
what about if i get it running....and get a really nice black paint job....what do you think il get for it then?
Old Jun 7, 2004 | 10:27 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
if its not running its worth about $500, if you get it running and get a good paint job then $2000 is easy attainable.
now heres the sad part, a good paint job will cost over $2000 so your already out over $ 2700 (paint and parts)
my advice to you is get a nice paint job, get it running and then you have a nice z28 with a 350 in it thats no longer a project car.
wish i could help ya out more man but sadly without it running and it being in primer, no one will pay more then $600
Old Jun 8, 2004 | 02:12 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
if you're just looking to cash out for as much as possible right now, I'd say the most profitable means is parting it out. Sell all that you can individually and then sell the frame with whatever is left and you'll still get a few hundred for that. If you get it running, I'm not sure if getting a cheap paintjob would be a profitable move or not.
Old Jun 8, 2004 | 04:20 PM
FLYNLOW92rs's Avatar
To your average consumer
It's an 19 year old car that doesn't have original engine, has no paint on the exterior and doesn't even run
$600 tops (as mentioned)
Now with Maaco and some cheap parts to get it running, maybe $1,500
Old Jun 8, 2004 | 07:09 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
around here runing is stong condition and terrible intewrior and primer will get ya 2500, we bought mine for 1900 in that conditon at a dealership you cant find any of them for less then 2300 now, value is going up guys.
Old Jun 8, 2004 | 08:10 PM
2out_The_Left's Avatar
dime a dozen up here. i bought my 86 in stock condition, PERFECT in everyway. the carpet had a stain on it. it had the orginal floor mats and everything worked. i couldn't have asked for a better car. the guy actually drove it from california to NH because he just relocated because of his job. i was passing by and saw him putting a for sale sign under the wiper, pulled over and asked the price.... 1500 he says. i wrote him a check right there and drove it home the next day. deals come and go but this was the best deal i'll ever get. lol the GTA for 1000 came close but still didn't beat this.
back to the topic at hand, i would get the car running and forget the paint. nothing wrong with primer. leaves the buyer open to paint it his desired color. ask 2k or best i'd say. you won't sell it to someone whos looking to drive it away, or even the highschool kid looking for a car. with a car like that you'll attract people like me who like to build it to their standards and can see past the minor things about it. but definetly, get it running before sale.
Old Jun 12, 2004 | 06:22 AM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
I just bought a nice '89 Formula with t-tops for $1100.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
