What's required to replace the window felt
Old Jun 10, 2004 | 03:12 PM
jimmysauter's Avatar
Car: white 1991 z28 w/b;ack racing stripes
Engine: TPI 350
Transmission: world class t5
I put a new driver side window into my 91 z28 and some of the screws got left off that hold down the felt seal on the outside of the car (That scrapes off the dew). It worked fine for a while, but now the seal is starting to not sit level anymore and it gets stuck on top of the window if I roll it all the way down. How hard is it to replace those screws. As I recall they are not too accessable with the window in place. Should I try and put new screws in, or while I am in there should I replace the felt seal as well?
Old Jun 10, 2004 | 08:40 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Its not hard. Just gently ease the glass out of your way for the ones in the middle. The end ones closest to the windshield may require you to move that corner thing. I had to. No big deal, just take off door panel and take out two screws that hold it. Either mark bolts or note position so as to replace in same location for proper seal.
I recently began the interior/exterior phase of my Camaro. I took all that stuff off to send it to the body shop.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Mar 18, 2019 08:29 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
