Firebird Noses
Old Jun 12, 2004 | 02:18 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
Firebird Noses
Hi! I used to own a 1985 camaro with a 2.8, now I have moved onto a 1986 Firebird with a 2.8. I am just curious what is required to do to put an 82-84 nose on the car, or if I can put a 91-92 nose on the car, because the one on there now has a small crack in it.
Brendan
Old Jun 12, 2004 | 12:31 PM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
For an 82-84 you may need to get the honeycomb under the nose and thats it...you may not even have to. For 91-92 I believe you do and to make it easier you may need the metal impact bar since they're slightly different. Also your headlights will not clear the bumper of a 91-92 so you'd need to either grind off the lip of the bezel or get 91-92 bezels.
Old Jun 12, 2004 | 07:27 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
The headlight bezels are different on the 85-90 nose.
They sweep up at the edge toward the fender, when viewed from the front, trust me, I've checked into this. But that easy, as the 82-84 bezels will mount right to your 86 headlight assembly.
That same area on the 82-84 bezel, is more squared off, when viewed from the front.
83 Crossfire TA
Jan 3, 2016 01:26 PM
jtwoods4
Sep 3, 2015 05:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
theshackle
Aug 22, 2015 06:52 PM
