fender problem.
Old Jun 13, 2004 | 05:51 PM
miamivice's Avatar
Car: 88 GTA
fender problem.
ok guys i got a problem,
i was just trying to unbolt my drivers side fender....was trying to loosen the bolt that is behind the wheel down below and the bolt just broke off, leaving the threaded part still stuck in the sheet metal that is attached to the car. what the heck do i do?
ideas???
Old Jun 13, 2004 | 06:25 PM
qiker's Avatar
Car: 1989 trans am gta
Engine: tpi 5.7
Try drilling it out with a smaller diameter bit .If not get some easy outs from sears it is a kit that will be worth it's weight in gold if you are planning on working on your own car..Good luck
Old Jun 13, 2004 | 07:10 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
drill it out, use a clip and a 10mm bolt and your set, or you can be lazy and weld them on like i did ...lol...
Old Jun 13, 2004 | 07:46 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
After I got mine off (rusted like hell)
I wirebrushed the bolts, WD-40'd the **** outa them and the bolt hole (which is threaded)
covered it in neverseize and stuck it back in and out a few times and now it works great
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
HoosierinWA
Oct 7, 2015 10:15 AM
