Gauges
Old Jun 29, 2004 | 12:43 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Gauges
I haven't taken the gauges out yet.. but i have the dumpy 85mph gauges in my 87 Iroc. I wanna upgrade to the 115 or the 140.. the thing is.. i dont know a damn thing about them.. lol. How do i know if the gauges are on a speedo cable, controlled by the comp, etc. I'm sure i will find other info on this board by searching for installation instructions, i just wanna know what i can do (on what i can buy that will work relatively easily)
Old Jun 29, 2004 | 01:08 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Your 87 is cable driven speedo. There's a release clip at the back of the speedo, you have to undo the cluster first. You should be able to find more than enough info using the search, it's been mentioned a few times
Old Jun 29, 2004 | 01:23 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
i bid on a 140 speedo entire gauge cluster on ebay. Says it came out of an 85 camaro (didn't specify on package).
After i get it, all the gauges in the cluster will hook right up (correct??). Now, im assuming the calibration will be off.. what do i do from there? take it to an autoshop and have them replace gears in the 700r4? i have absolutely no idea what to do, so all help is greatly appreciated. Thanx
Old Jun 29, 2004 | 12:29 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
the 140 mph gauge cluster from an 85-89 will plug right in. there is no calibration needed. just pull out the old cluster, put in the new one, and you're all set. hope you have skinny arms, i had a hell of a time reaching back there to disconnet and reconnect the speedo cable. a little advice i would give, take out the drivers seat. i had to lay on my back, wasn't too comfortable with half my back on the seat, half on the floor. there is an article in the tech article section on how to swap the clusters, it's quite easy.
Old Jun 29, 2004 | 12:33 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Thanx a lot... now i just cant wait to win the bid and for it to come home.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
