1989 IROC Hatchback problem
Old Jul 1, 2004 | 01:02 PM
mot's Avatar
mot
Hello, I;m new to this forum so any help would be appreciated. I just got an '89 IROC-Z 305 TBI and I have a problem with the hatchback. When closing it, the motor just keeps running but the lid won't stay shut. The release seems to work fine, though. I tried clamping a screwdriver in there to simulate the hatch being closed. It did the same thing. The screwdriver was clamped but the hatchback motor kept running. The release worked fine. Any ideas?
Old Jul 1, 2004 | 02:23 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
The gear nut on it or the housing is broken more than likely if it keeps running. Pull the trim off the rear and look at it at the bottom of it there is a plastic housing, it gets broken if someone slams the hatch. It breaks at the srews so it may be hard to see, also the gear nut inside of the housing can get broken or striped and cause the same problem. It would be a good idea to replace it and make sure to grease it up good.
Is it actually grabing the screwdriver or hatch just not pulling it down right.
http://www.top-downsolutions.com/
He sells all the parts you will need to rebuild the latch, he also sells completly rebuilt latches.
colton_carlson
Mar 8, 2019 12:21 PM
Derick15
Sep 17, 2016 05:28 PM
kyleb24
Aug 15, 2015 08:24 AM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
mustangman65_79
Aug 11, 2015 03:17 PM
