Trim paint
Old Jul 6, 2004 | 01:58 PM
Vaker's Avatar
Car: 1986 Trans Am, 1989 Firebird
Transmission: 700r
Trim paint
I have blue trim in my 89/86 trans ams, I want to change them to the tan trim, should I order tan ones, or could I just paint them which will cost me less?
If its possible to paint them, and get factory look, could someone tell me how I should do it without messing it up, and what paint to use?
And by the way whats a good site to order factory seats from, besides ebay since I can't find any tan color :'(
Old Jul 6, 2004 | 03:01 PM
toecutterv8's Avatar
Car: 1990 Z28,1980 Z28 CAMARO
Engine: 1980 Z28 350,1990 Z28 454 TRANSPLANT IN PROGRESS
Transmission: TH400 WITH GEAR VENDORS.
Trim Paint,Go With Deltron 2 Pack.......
Hi there,
I myself have encountered this problem many times,I have found the best way is to use a quality two Pack paint like Deltron(ppg),The correct primer amd adhesion promoter,then obviously your colour coat.I then laquer on top of this,you must use a small amount of flexible additive for the flexible plastics.The finish is stunning,and VERY durable,the only down side is that you are left with a very shiny finish,for a more standard finish you could try some matting agent.I have tried the proper plastic Dyes,i have found them very watery,very time consuming,and non impressive results.The last time i tried it i purchased the whole package from the same company,the cleaner,the prep,the dye,the finisher,the top coat,the finish was s!!t.I have even done a dash pad with two pack,the results were great,and the finish lasted the time i had the car.I live in the UK so you guys may be able to get better quality Dyes than I can.If you are interested i can go into more depth.On buying the trims i would imagine they would cost a fortune?????
Old Jul 6, 2004 | 03:04 PM
WARNING ON MY ABOVE ARTICLE....
Hi there i forgot to say that one disadvantage with two pack is that you absolutely must wear a suitable mask(preferably air fed),also if possible spray outside where you wont get a build up of Vapours.
Old Jul 6, 2004 | 03:55 PM
Vaker's Avatar
Transmission: 700r
Do you have al ink to where I could order these products? And does anyone know the color code for the tan color interior trim? that came in 86 trans ams?
Old Jul 6, 2004 | 04:06 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I would try to find a beige set from the junkyard before painting them. Even if you find a set and still dye them any scratches you get will be less noticiable.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 6, 2015 11:40 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
