89 firebird hood ???
Old Jul 26, 2004 | 05:15 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
Would removing the plastic flap at the back of my factory firebird formula hood reduce engine temps, or under hood temps? And why the hell would pontiac put a hood like that on a car and only make it cosmetic instead ot functional.
Old Jul 26, 2004 | 09:13 AM
Mirage's Avatar
Car: 1991 Firebird GTA
Engine: 350 C.I
Transmission: Auto 700 R for now
some of those hoods are functional, not sure of the details on them, but i know that some are actual working assemblies, removing the flap will help reduce temps, but water can get in, so it is up to you if you want to pull it, or you can make it functional, i.e set it up to open and provide a directed flow of air to your intake at high throttle. hope this helps
Old Jul 26, 2004 | 09:44 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I would assume your talking about the Formula Hood, it was also used on the 82-84 Trans Am. As far as the functioning of the hood in 82 it was an option, 83 & 84 it seemed to be pretty standard equipment to have a functioning hoodscoop.
All Formulas from 1987-1992 the hood is for decoration (besides it looks great!! )
By removing the blockoff plate you will force more air into the engine compartment, Not a bad thing really, but it would be harder to keep it clean. Also you will get more water under the hood, especially when driving, since that is a high pressure area.
IF you decide to remove it you may want to take a piece of sheetmetal and screw it to the underside of the hood where the insulation is at the hood scoop. it could pull down over time because of the extra wind coming in.
John
colton_carlson
Mar 8, 2019 12:21 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
deracer
Apr 11, 2016 12:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
