Bad Ebay GFX's HELP!
Old Jul 26, 2004 | 11:23 AM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
I just bought some 91-92 camaro GFX's for my 88 IROC. I got 6 pieces, 2 rocker panels, 2 door skirts and the 2 small pieces for the back end. The only problem with the GFX's are the freakin rocker panels! He told me there was a slight crack on the left side, but failed to tell me that the same rocker panel had had all of its hangers riped off! How am I suppose to hang this now? Or should I just go to Hawks and buy a new one!?
Help!
Old Jul 26, 2004 | 12:43 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
That sucks. Have you tried telling the guy about it? You should still be ok though. The brackets for each end and the screws from the top will be enough to secure it in place.
Old Jul 26, 2004 | 03:05 PM
dacboyz's Avatar
Car: 89 Camaro
Try using what you have and if you cant make it work try the junkyard. Man I was just there today and saw a decent set off a 91 camaro. I didnt need them so I didnt get them. Also I would contact the person from ebay and let them know about it. Maybe they can refund some of your money.
Old Jul 26, 2004 | 03:14 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
I send a letter to the guy i bought them from, no reply yet though. (Dought i well get one) I live in Iowa, and I called every junk yard in the phone book, no one has a 91-92 camaro.... Lol i hate this state!
Old Jul 26, 2004 | 03:49 PM
dacboyz's Avatar
Car: 89 Camaro
I wish I would have known that before I went to the bone yard I could have pulled what you needed. The nexxt time I go I will see if its still there and let you know. Also I would leave negative feedback for the guy if he doesnt respond. Its a shame people have to rip people off like that.
Old Jul 26, 2004 | 04:12 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Sweet man thanx alot! I looked my my own 88 GFX's for my car today, it has all the tabs in place, so is there anyway i can use my broken rocker panel and get away with no useing the tabs and only the main bolts? (If this makes any sinse) :lala:
Old Jul 26, 2004 | 05:04 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
why not just re do the mounts with some fiberglass reapir kit from bondo. i did some repairs on mine with that stuff and it is rock hard when done. it comes with the resins and fiberglass material i would just mix some up and cut the tape to fold over the entire tab and when it hardens drill a hole in it. should work without a problem.
jeff
Old Jul 27, 2004 | 12:08 AM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Old Jul 27, 2004 | 06:45 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Exactly.
Old Jul 27, 2004 | 08:45 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Post the guy's Ebay user name so we can beware of the guy.
Old Jul 27, 2004 | 11:06 AM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
The guys Ebay name is "partsfeeder" Today i am going to see if i can just use the screws to bolt it on with without the tabs. Or ill just say screw it and buy a new one for $100 on hawks.
Old Jul 27, 2004 | 11:28 AM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Originally posted by stalin05
Alright, ill look into it. I just got an email back from the guy and he said that it wasnt true about the tabs (ill take some pictures of it and post it later on) He said he told me about the work that needed to be done on it :bs: but ill look into all my options.. hope this works!
When I installed '91-92 aerodyamics on my '87 I had to fabricate a metal piece to fit inside the body and hold the studs on the rear of the long pieces on each side of the body.
Old Jul 27, 2004 | 03:17 PM
Mirage's Avatar
Car: 1991 Firebird GTA
Engine: 350 C.I
Transmission: Auto 700 R for now
to mount the gfx where there are no tabs is not hard however, to get it just right, can be time consuming, depending on your level of fabrication experience. flush mount bolts, custom brackets that bolts to the gfx and screw to the original holes in the body, i have done this before many times, and it works, and is not visible. I do like stainless steel for the bolts and if possible, the steel, as there is no welding involved. The brackets can be any shape you like as long as they are all the same, and look good if need be. hope this helps someone!
Old Jul 27, 2004 | 03:18 PM
Mirage's Avatar
Engine: 350 C.I
if need be, i will go into more detail on this one if there is a demand
Old Jul 27, 2004 | 03:30 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
yes please if you could that would be great! :hail:
Old Jul 27, 2004 | 10:46 PM
Duck's Avatar
Engine: 5.7
Here's how I mounted the gfx on my '87.
Old Jul 28, 2004 | 01:20 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
ok guys, i just took off my drivers side 88 GFX's... They look a bit different from the 91 GFX's... What mods do i need to do for them to bolt on? Oh and, does anyone know what the heck holds the back part of the 88's on!? We couldnt figure what was keeping it in place after we took out every bolt we cold find
Old Jul 28, 2004 | 05:29 PM
aerosmithr0cker's Avatar
Car: 1991 Z28 clone & 1985 Fiero 2M4
Engine: 305 TPI (In Progress, Camaro) & 2.5L 4 cyl soon to be 3.4
Transmission: 700R4 (Camaro) & Isuzu 5 speed (Fiero)
the piece that is on the quarter panel before the bumper is held in from the inside if you take out the rear plastic you should be able to get to the bolts.
Drone358
Dec 10, 2015 08:16 PM
e3pres
Sep 9, 2015 01:51 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
snakeshooter
Sep 7, 2015 11:15 AM
Ian Irvine
Sep 4, 2015 08:08 AM
