lighting up the bird
Old Jul 26, 2004 | 08:27 PM
Mirage's Avatar
Car: 1991 Firebird GTA
Engine: 350 C.I
Transmission: Auto 700 R for now
on the a$$ end??, Anyone have a how to on lighting up the bird in the center of the tail lights, , already tried the search without luck or maybe i just suck today, not sure, but help is appreciated
Old Jul 26, 2004 | 09:09 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
would wire up a socket for a bulb that has one end grounded and one end on the ACC slot in your fuse panel... when you turn your car on or on ACC then it will light the bulb... you will need to drill holes to accomodate the socket.
Old Jul 26, 2004 | 09:28 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
You could always splice into your tailights, so that it comes on with your running lights.
Old Jul 27, 2004 | 03:05 PM
Mirage's Avatar
Engine: 350 C.I
As far as the wiring goes, i have no problem, and will probably have that set on to the DRL with the tails and fogs, however , i am wondering how to clear the bird to allow for light to pass though, as mine is black on the inside
Old Jul 27, 2004 | 09:24 PM
Orinackra's Avatar
You have to scrape the paint off ths inside...If you tilt it at an angle, you can see the shape outline of the bird. Get a dremel or a razor or something, and carve out out the shape. Just be careful, its really obvious if you mess up...
Old Aug 11, 2004 | 09:31 AM
wood123firebird's Avatar
I have done this on my 86 TA, with a dremel tool, I carved out sections of the mount plate near the edge of the bird where I could let light it from the back on the edges. then I took a few of the xmas tree mini bulbs and epoxied them in place with clear epoxy. you could probably use the high out put LED's now, I did this a long time ago.
The lights could be wired up with the regular parking lights.
GTAman
Mar 15, 2019 11:40 AM
Jae992
Aug 27, 2015 09:07 AM
Catcher55
Aug 15, 2015 07:08 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
