removing rear trim panel (sun shade)
Old Aug 1, 2004 | 10:41 PM
ratedrookie's Avatar
I'm trying to remove the drivers side rear trim panel, the one with the lock box, but I've run into a problem. How do you remove the roll out sun shade? I don't think the trim panel will come out with the sun shade in there, but I can't figure out how the darn sun shade is removed. I've used the search and can't seem to find out how to remove it, so any help is appreciated.
Old Aug 1, 2004 | 11:33 PM
OSU76LT's Avatar
Car: 84 Z28
Grab one end and push it toward the other end to compress it, and then lift it up and out. Once you've removed the shade, there are 2 screws holding the bracket in that you'll need to remove to get the trim panel out.
Old Aug 2, 2004 | 12:59 AM
Thanks! I'll have to try that tomorrow.
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
BlackBoulder
Aug 11, 2015 11:15 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
