door aligning
Car: 82 z28
Engine: 350 carbed
door aligning
ok i just put better doors on my 3rd gen. it seems that the doors close perfect when the back bolts are not in, then when i put them in its lower.(so it don't close very good, without lifting up) and it rubs the fender. so what is the best way to align the doors. thank you
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if you can lift it up then id suggest putting in new hinge bushings
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Try checking out Top Down Solutions. They sell everything required to repair door hinges and align doors correctly. I've used their kit and think it's great!
Here's the link: http://www.top-downsolutions.com/pro...products_id=33 By the way, TDS sponsors www.thirdgen.org, so supporting their business helps us all. Good luck!
Here's the link: http://www.top-downsolutions.com/pro...products_id=33 By the way, TDS sponsors www.thirdgen.org, so supporting their business helps us all. Good luck! Thread
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
