a-pillar repair
Old Aug 11, 2004 | 01:16 PM
Mirage's Avatar
Car: 1991 Firebird GTA
Engine: 350 C.I
Transmission: Auto 700 R for now
a-pillar repair
problem is, mine is rusted in the bottom corner of the drivers side, I am thinking section the bad boy, whats everyones thoughts on this??
Old Aug 11, 2004 | 03:14 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's amazing how many I've seen rusted there.
How bad is yours? I would think making a new piece out of flat tin and welding it into place would be easier than sectioning it, but if it's bad enough then drastic measures might be in order.
Old Aug 12, 2004 | 10:50 AM
Mirage's Avatar
Engine: 350 C.I
it is just the outer skin that is killed, so replacing the face with some carefully formed steel and a little fibreglass majic should not be that bad, my only concern is body arc in that location breaking the fibreglass!
Old Aug 12, 2004 | 11:13 AM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
I just did this repair on mine. I think it mainly happens on the car that have T-tops. The tops of the pilliar is open or rusts open and the water runs down and has nowhere to go. I just cut the top skin and welded an new piece of sheet metal on. Was a relatively easy fix. I wouldn't suggest sectioning though. The inside is built really well and didn't see alot of rust inside. I pulled the foam out and sprayed with some RustX then packed some new foam in and welded it together
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
