Removing Kick Panel
Old Aug 17, 2004 | 11:55 AM
RamoneZ's Avatar
Car: 91 Z28
Transmission: TH 350
Removing Kick Panel
I can replace an engine, assemble a child's play set, program a VCR but I CANNOT determine how to remove the kick panel from my 91! I am referring to the small carpeted piece under dash. I could just tear it up but that is not my goal. I could not find this through the "search" here or in the manual. HELP!! Thanks.
Old Aug 17, 2004 | 01:28 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
I think there are two screws holding on the kick panel on the drivers side.The first also holds on the level you pull to pop the hood. Feel around the carpeted area around the center of the kick panel and see can you locate the Phillips head screw. It can be difficult to find it as the carpet can cover over the screws especially if the panel has never been removed before. There may also be one where the kick panel joins the floor panel (plastic panel on the door sill you see when you open the car door)
If it's the passenger side kick panel you want to remove there are two screws on the carpeted area.
Hope this helps.
Old Aug 17, 2004 | 02:10 PM
Aredross's Avatar
Car: 1990 RS coupe
Engine: TBI 305.
in my 89 there was only one screw but in my 90 it seems to be held in by other things as well
Old Aug 17, 2004 | 03:45 PM
123jon321's Avatar
Car: '86 iroc
Engine: lb9 305
Yeah, I only have one screw i my '86........
Old Aug 17, 2004 | 04:04 PM
RamoneZ's Avatar
Car: 91 Z28
Kick Panel
Hey thanks! There are 2 screws on pass side and one on driver side. All were very well concealed by the "carpet". I pretty much had to force the screwdriver through it to make contact.
Old Aug 17, 2004 | 07:18 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Odd. I have three on my 92 TA passenger side. Two in the spots I'm used to (low under the door, and dead center) but also had one up top almost under the lower dash plastic. Almost broke the damn thing before I found the third one..
Kevin D.
Vintageracer
Jan 10, 2020 05:33 PM
tcflint
Sep 14, 2015 04:55 AM
fbirdroller
Sep 2, 2015 10:27 PM
3rdgenparts
Aug 8, 2015 07:09 PM
z28addict8490
Aug 7, 2015 08:48 PM
