please help new wheels don't fit
Old Aug 19, 2004 | 02:13 PM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
I just got my 17" firehawk wheels in from SLP.
The rear fits fine but the front hits the outer tie rod end.
Can you mount the tierod from the top down or does it have to be bottom up?
My car is a 86 transam with a rear diff from a 94 firebird.
Old Aug 19, 2004 | 02:20 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
The rears fit only because your rear is 2" longer per axle than a stock 3rd gen rear. You need a 2" wheel adapter for the front wheels to fit. Try http://www.skulte.com/adapters.html
Old Aug 20, 2004 | 07:38 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
Thanks for the info
SLP told me that if I put the 94 diff in the wheels would fit.
Any other places anyone would recomend getting these spacers?
Old Aug 20, 2004 | 09:33 AM
ops32's Avatar
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Putting 4th gen wheels on 3rd gen cars requires adaptors. The offsets are totally different, as you've found out! Like 91formula said, the rears fit due to the 4th gen rear being on your car. Another place for adaptors is Hawks (see link at top of page).
ops32
Old Aug 20, 2004 | 02:06 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
You can also try eBay. I bought a set off eBay for $165/set of 4- shipped. There are 2 or 3 guys on there that custom make them. If you contact them, you might get them to sell you a pair instead of 4. If you have to buy a set, you can probably sell the 2 spares to someone else who has a 4th gen rearend & only needs 2.
Old Aug 24, 2004 | 11:32 AM
Engine: 5.7, 5.0
Hey Firebird 383,
I'm the guy who bout your 17" WS6 wheels. How come you went with the 16" wheels? The 17's look killer on my formula.
Old Aug 24, 2004 | 11:42 AM
GarageToys's Avatar
Originally posted by 91formulaSS
Hey Firebird 383,
I'd love to see a picture with the WS6's on it. Those were great wheels. I kinda fell into these (they were taking up space at my brother-in-law's house. I bought the wheels/tires and adapters for about 1/2 of what you paid for the WS6 wheels alone)
Old Aug 24, 2004 | 11:43 AM
Engine: 5.7, 5.0
I'll see if I can steal someones digital camera.
Old Aug 24, 2004 | 01:03 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
Ruiny, did your wheels come with spacers? If not, or you need thicker ones, try the spacers at this link: http://www.mrgasket.com/ProductsList...1&selection=28 They're on page 4. I had the exact same problem with my Firehawk wheels. I used thicker spacers and I also ground the outer bottom portion of my tie rods slightly to get just enough clearance. Part of my problem I had was that I had Perfect Circle tie rods instead of the GM ones. The Perfect Circle tie rods have a larger diameter. I'm a little bit of a perfectionist, so I ended up making my own spacers and that's a possibility for you too if you have some shop skills. Hope that helps.
Old Aug 26, 2004 | 01:39 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
This really is the best application for those spacers.
Ruiny, either get the already listed ones from skulte for our specs or use our sponsor hawks that has an ad right on the top. You can search for the info too on this site on why adapters should be necessary when putting 4thgen wheels on a thirdgen.
Including things like a-arm, tierod, and bumpstop clearance that can cause a nice variety of issues. The adapters are necessary, as you can see based on the fact that Mr. Gasket doesn't make 2'' spacers, but a few companies make 2'' adapters.
Old Aug 27, 2004 | 02:28 PM
Engine: 5.7L TPI
Oops, my mistake. I was under the impression that you had the original Firehawk wheels. You guys must of thought I was totally clueless. Yeah, the Mr. Gasket spacers definitely wounldn't work.
Old Aug 28, 2004 | 12:11 AM
Engine: Your Momma
lol, yeah it sounded like that originally when you said that you had to modify the tie rods and I figured you probably went through a lot of crap then.
Old Aug 30, 2004 | 08:43 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
Thanks for the replies I was away on holidays for the last week with no computer to check up with.
I ordered the Suluke adaptors.
But now am a little scared due to some other posts of people having their adaptors fail.
Is this a real possiblility?
What can I do to ensure that they don't break.
Thanks again
Old Aug 30, 2004 | 08:53 AM
Engine: 5.7, 5.0
I have had the Skulte adapters on for almost 6 months, drove from Mass. to N. Carolina, probably put 10 thousand miles on with no problems what so ever. Andris Skulte races his car with the adapters on, with no problems. Just make sure you follow the directions and torque them properly. Don’t use an impact gun, it can stretch your studs due to excessive torque.
Old Aug 30, 2004 | 08:54 AM
Engine: 5.7, 5.0
Can you elaborate, or link a thread, on how these adapters "fail"?
Old Aug 30, 2004 | 09:30 AM
GarageToys's Avatar
LilHurmy03 recently had one fail. There are 2 threads about it and in both threads he has been asked what happened & hasn't yet responded. Here is one of the threads:
https://www.thirdgen.org/techbb2/sho...hreadid=257012
Old Aug 30, 2004 | 09:42 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
I think that is the same one I was thinking about.
So am I to understand that they don't normally fail at all and I don't need to worry?
Also how tight should I torque the adaptors and then the wheels?
Old Feb 7, 2005 | 01:43 PM
Engine: 5.7, 5.0
Bet you thought I forgot.
Attached Thumbnails please help new wheels don't fit-c-documents-settings-nicholasr.wmbpumps.000
Old Feb 8, 2005 | 07:54 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
thanks for the pick
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
milk
Aug 10, 2015 06:26 PM
