Painting T top center bar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
i might be repainting my t top center bar and wondered if my steps are correct
1. thoroughly clean with ammonia or other cleaning source
2. clean off any rust/wetsand even
3. re clean
4. spray on primer to protect from future rust
5. all purpose black spray paint
then finished
any other steps i should add in or paint recommendations
3. re clean
then finished
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Not too far off...
clean and degrease
grind or blast existing rust
fill any pits or weld holes
ETCH...and this is a biggie, It will give you your hold out
prime with a good 2k primer
sand, wax and grease remover, tack off, and refinish
Your choice trim black or body color.
clean and degrease
Car: 1989 GTA
Originally posted by KEVIN G.
Not too far off...
clean and degrease
Not too far off...
clean and degrease
is it a certain type of primer or what????
Should i use krylon flat black?? or other paint spray product
Engine: 305 CARBED
Etch is just what it implies...It etches the metal for adhesion and maximum holdout. It has body and is essentially an acid.
The precursor was the Epoxy primers, and wash primers.
Some are two part, some are spraybomb
Axle/Gears: 3.45, 3.27, 3.27
Re: Painting T top center bar
3. re clean
then finished
3. re clean
then finished
Lon
Car: 83 Z28
Engine: 400
Transmission: Th 350
Axle/Gears: 3.27 9 bolt
I agree with what lonsal and the others said but be sure to ad flex aditive to your paint I didnt and not long after I started driving my car again found a crack in the paint around a screwhole maybe I overtightend the screw or the lift that occurs at speeds did it but it is messed up now
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
you don;t need flex agent that is for plastics. you had an adhesion issue or paint to thick.
jeff
jeff
I'm strongly considering glass-bead blasting mine and having it powder-coated. The only down-side is that the finish appears to be a satin black instead of gloss black. If it was gloss black I could send it with one of my regular batches to be powder-coated and save on a minimum lot charge.
There are some other parts that appear to be satin black also, so I'll gather them up and send them all at once.
Lon
There are some other parts that appear to be satin black also, so I'll gather them up and send them all at once.Lon
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
NBrehm
Aug 5, 2015 07:57 PM
