Window Problem Please Help
Old Aug 24, 2004 | 06:13 PM
dacboyz's Avatar
Car: 89 Camaro
My drivers side window rattles alot and when I have it open part way it moves from back to front by the triangle. Kinda slides alot back and forth. I dont know how else to explain it. How do I fix this? It is driving me nuts.
Old Aug 24, 2004 | 06:27 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
take off the door panel and see whats going on in there sounds like you have something broken or loose on the window regulator
Old Aug 24, 2004 | 06:59 PM
dacboyz's Avatar
Car: 89 Camaro
Thanks I will do that but does anybody have pics of what to look for?
Old Aug 24, 2004 | 07:57 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
ask and ye shall recieve.
i just happen to have my car in peices still..
first pic two bolts on top right at tringle peice.
second pic 2 bolts in door hold angle of guide.
triangle is part of the window felt track peice.
Old Aug 24, 2004 | 07:58 PM
JeffW's Avatar
Engine: 305 tpi LB9
the two bolt are in line top to botpm on the hinge side of the door. you can see one of them in the first pic also.
hope this helps Jeff
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
neekolzun
Aug 24, 2015 04:59 PM
