dash rubbing door?
Old Sep 11, 2004 | 12:31 AM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
dash rubbing door?
my dash has rubbed my door since i bought my car. i am finally getting fed up with the damn thing rubbing and was wondering if there is an adjustment i can make to get it to stop. it is only rubbing on the corner that sticks out toward me on the driver side. what can i do
Old Sep 11, 2004 | 01:05 AM
Dave's 89's Avatar
Car: 89 IROC-Z
Axle/Gears: 4th Gen/3.42
Has it endured any major frame damage in the past?
Jeez, if you spent as much mney under the hood as it looks like you have on cosmetics you'd be running 14's easy!
Old Sep 11, 2004 | 01:38 AM
EvilCartman's Avatar
Car: '82 Z28
There's some adjustment if you take the dashpad off. You'll see a couple of big nuts at eather end of the dash that you might be able to loosen and push the whole dash to one side then re-tighten. That's about the only thing I saw last night while putting my new/used dashpad in.
Old Sep 11, 2004 | 10:57 AM
Engine: LO3 and LT1
no no major frame damage in the pasti had a litle bit of damage to the front nose last year but nothing too extreme to make my frame crooked and i ajust installed sub frame connectors . they went in fine so im assuming no frame damage but the door was rubbing the dash way before any of this
Old Sep 11, 2004 | 11:05 AM
Engine: LO3 and LT1
[PHP]Jeez, if you spent as much mney under the hood as it looks like you have on cosmetics you'd be running 14's easy![/PHP]
yea your right that will come next
Old Sep 11, 2004 | 11:07 AM
Engine: LO3 and LT1
i think i did that wrong
Old Sep 11, 2004 | 05:25 PM
Car: '82 Z28
Yes you did
Old Sep 13, 2004 | 02:15 AM
miamivice's Avatar
Car: 88 GTA
my whole entire dash piece....the plastic part that the pad sits on was actualy set a little off to the passenger side....causing the dash pad to hit the door pannel. that is another thing that could possibly be causing the problem. id check to see if the dash pad can just be adjusted first.
Vintageracer
Jan 10, 2020 05:33 PM
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
