Part # for Firebird pass. side headlight mounting bracket?
Old Sep 13, 2004 | 09:46 AM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
It was raining and my headlight wouldn't come up. I had to get home, so I tried to pull it up as I have successfully done before. This time, I broke the mounting bracket! Also, the arm that goes from the headlight motor to the headlight isn't attached anymore. I'm not sure if it is broken, I'll have to check again. Does anybody have the part number for the mounting bracket, or one to sell me? Thanks
Click this link, there is a drawing that shows the mounting bracket.
http://www.hawksthirdgenparts.com/in...il?v=1&pid=464
And yes, I do know about the TDS headlight repair kit, and I will be ordering one.
Old Sep 13, 2004 | 12:50 PM
Morley's Avatar
I may have what you are looking for. Your car uses the large headlight correct? (not the one that is the same size as the camaro)
Old Sep 13, 2004 | 02:18 PM
I believe it is a little bigger than the Camaro headlight. My car is an 88 GTA. The later (91-92 I think) Firebirds had smaller headlights. The mounting bracket I need is the large piece that is in the very back of the headlight area. It is bolted to the radiator support. Also, the "arm" that connects the headlight motor to the headlight is broken off of the motor. Does any of this sound familiar to you?
Here is a pic of the radiator support...the headlight bracket attaches to this:
http://www.speedyautoparts.com/image...large/5745.JPG
Here is a picture of a headlight motor that shows the arm that I need:
http://store1.yimg.com/I/dpstore_1807_32749009
This sucks, my Camaro's fuel pump is dead and now the
GTA's headlight is screwed up
Old Sep 13, 2004 | 04:29 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The bracket number can be found digging through the guide in my sig.
The arm and the little rubber 'grommet' thingys that go in it are not available (well.. I should say, the local pontiac dealer did a parts search for them to no avail). Best bet is the j/y or possibly making one.
Old Sep 13, 2004 | 04:36 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
I have a spare complete pass. side headlight mounting assembly with the motor and it works great off of my friends old 88 formula, pm me if your intrested and we can work something out.
Old Sep 13, 2004 | 04:40 PM
PM sent
Old Sep 14, 2004 | 01:20 AM
Morley's Avatar
I also have the complete assembly minus the light bezel. Let me know if you still need/want.
Old Sep 16, 2004 | 11:03 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
Bracket package-headlamp mounting RH 1987-89, GM part number 16509200. Linkage kit, GM part number 22030717.
Old Feb 2, 2012 | 03:39 PM
kenya42077's Avatar
Re: Part # for Firebird pass. side headlight mounting bracket?
Looking for a headlight bracket for a rh headlight bracket for a 91 firebird someone please help me
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Elliswon
Aug 10, 2015 12:33 PM
1nastygta
Aug 8, 2015 07:38 PM
