T top bag and wheel offset questions
Old Sep 20, 2004 | 07:06 PM
7t1goat's Avatar
Car: 87 GTA
Does any one know of a source for T top bags? I have an 87 GTA that I just bought which did not have one. I also noticed that the diamond wheels appear to have different offsets. The front wheels have a wider lip. I imagine that this means that I can not rotate them to the rear.
Another strange thing is that the car has rear drum brakes. Everything I have read says that GTAs came with 4 wheel discs.
Old Sep 20, 2004 | 07:47 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
might not be a gta, check you rpo codes for y84
Old Sep 20, 2004 | 07:48 PM
Robg's Avatar
Car: '85 Z28
I've seen T-top bags on ebay pretty often. Don't know about the wheel question.
Rob
Old Sep 20, 2004 | 08:19 PM
7t1goat's Avatar
Car: 87 GTA
My car has Y 84 listed on the glove box sticker. That's the first thing I checked when I saw the rear drums.
Old Sep 20, 2004 | 11:20 PM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
My brother has bought t-top bags off E-bay also.
And a buddy of mine, had a car just like yours, 305 TPI, auto, rear drum brakes, on an 87 GTA. We both understood a GTA to come standard with the 350 (5.7), and rear disc brakes. The only thing I could think of, was that those items were a credit delete option.
But why?? Save some cash on a car that looks the same to most other people?!? Who knows, wouldn't have been my decision, though!
Old Sep 20, 2004 | 11:54 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
GTA's weren't "guarenteed" 5.7 L v8's either. However, it is considered more "uncommon" for them to be missing one. 4-wheel disc was probably an option for T/A and GTA alike. AS i recall, the GTA option was more comfort than it was performance. Performance would be a WS6 formula.
Old Sep 21, 2004 | 07:36 AM
97-1LE's Avatar
Car: 87 Trans Am
Engine: Built 350 Cam, Headers
You can pick up a T-top bag at your local salvage yard for $ 15 to $20. That's what I did.
Old Sep 21, 2004 | 09:23 AM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
I should start selling stuff off of ebay again soon & when I do I will make sure I will put T-top bags on. But when I do they normally run $30-$40
Old Sep 21, 2004 | 09:54 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
A GM dealer video I have a copy of states that the GTA is for the person who wants the performance of a Trans Am, but doesn't want all of the eye candy.
7t1goat, the rear wheels have a 16MM offset. You are correct, you can not rotate the rears to the front, or the other way around. You can rotate side to side, unless, like the last owner of my car you put on directional tires.
Old Sep 21, 2004 | 08:14 PM
7t1goat's Avatar
Car: 87 GTA
Thanks for all the feedback. I have read that the 305 was put in T top GTAs because the engineers thought that the 350's torque would twist a car without a solid roof.
On my car, it seems odd that the wheels that appear wider are on the front, but I guess that's the way it's got to be.
Old Sep 21, 2004 | 08:19 PM
Ok that comment about the 350 Cars is wrong they put 350s in the Camaros & Firebirds with ts up until 1991. ( or it may have been 1990) I have a Irocz with a L98 Engine & t-tops. Its an 87.
Old Sep 21, 2004 | 08:44 PM
87GTA Runner's Avatar
Car: 87 GTA
In 87 you supposedly couldn't get t-tops with a 350, but sometime later in the year, GM allowed it. Starting in 88 you could. Then 91 and 92 you couldn't.
Old Sep 21, 2004 | 08:54 PM
Car: 87 GTA
Re: T top bag and wheel offset questions
Quote"Especially in 1991 and 1992, it seems that some GTAs were produced with this unusual combination. This option, RPO J42, featured front disc brakes and rear aluminum drum brakes, instead of the usual rear discs set-up. At present, there is no information on the reason that this particular set-up was used. It very well may have been part of a certain model option combination or an unusual option restriction. " Thanks to GTA Source page.
Old Sep 21, 2004 | 09:28 PM
Are you talking GTA, Transam or ALL Fbodys?
Old Sep 21, 2004 | 10:17 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Its not wider, it just has a deeper dish to it.
Old Sep 22, 2004 | 05:11 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
They stick out more. I have had 4 front GTA wheels on my Trans Am as well as 4 front Formula Wheels on my Formula.
Gives it a nicer stance since the back wheels aren't tucked in as much,
you can see the offset better in the picture of the Trans Am,
Old Sep 22, 2004 | 08:16 PM
7t1goat's Avatar
Car: 87 GTA
Thanks again for all the responses. I have a question regarding the headrests on my GTA. They are the kind that extend forward with a round **** on each side. The driver's headrest is stuck and does not go forward. The passenger's headrest works fine. I don't see how to remove them to switch them and can not seem to free the stuck one so it will go forward. Any ideas?
Thanks,
Tom
Old Sep 23, 2004 | 11:51 AM
89_IROC_98U's Avatar
For t-top bags, go to THIS guy: http://members.***.net/iroczdave1/IR...rts%20Page.htm
I ordered a zippered logo bag from him and it's mint except for the vinyl straps - the ends are faded. Otherwise, it's a perfect bag. $70 shipped. You could get an eBay bag, but why take chances?
- 89_IROC
Old Sep 23, 2004 | 12:31 PM
once again I ask In all Fbodys or just the GTAs & Trans Ams?
Damn I am so tired of being Ignored.
Old Sep 23, 2004 | 12:34 PM
I can't answer intelligently, but my reading on the boards says that the Camaro could not be had with CC1 and L98 in '91 and '92. The Firebird, however, doesn't appear to have had that limitation.
- 89_IROC
edit: I think '91 was the 'no CC1 with L98' beginning; the 1990 IROCs could be had with that combination. Mine is an '89 L98 with CC1.
Old Sep 23, 2004 | 02:52 PM
- 89_IROC
Mines a L98 With CC1 as well & its an 87 Thats why I was asking.
Old Sep 24, 2004 | 10:00 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
My mistake, I thought when he said that he meant the actual wheel itself and not the appearance of the car.
Old Sep 24, 2004 | 10:24 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
do your homework people! Just because 1 person said it does not make it so. The 350 with ttops was an option and was VERY available in 87. krazzycowgirl, this is info you already know since you have the car!
Old Sep 24, 2004 | 10:37 AM
The Reason Why I was asking was that I know that Gm allowed some stuff in the Camaros (or Firebirds) & Didnt allow the same thing in the other car.
I am still having problems with people trying to tell me my car is not stock from the factory.
Heck went to go buy belts for it & the Auto store Told me straight out that I have Serp. Belts in my car & NOT V-Belts. . Proved them wrong. By taking the car in & pics of other ones.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
