What Color to Paint!
Old Dec 13, 2009 | 12:10 PM
  #301
t5535's Avatar
Car: 87 Trans Am
Transmission: 700r
Axle/Gears: ones that turn
Re: What Color to Paint!
Yup that dark candy apple red is the color that I think I am gonna go with. Changing colors is just to much work. That red should match the jams and so on close enough for me. All thow I did see a black TA with the red (maroon) interior and it did not look bad.
Old Dec 13, 2009 | 12:31 PM
  #302
t5535's Avatar
Car: 87 Trans Am
Transmission: 700r
[quote=fb305svs;2197827]Dupont tripple black, 5 coats of clear... done in a body shop, took about amonth, they fit it inbetween other projects for me...
crumby pic, but it shows the color well
Did you buy that hood or make it? how high is the rise at the closest point to the windshield? I have to put some sort of scoop on mine do to the fact my intake and carb are too tall.
Old Dec 13, 2009 | 02:54 PM
  #303
83 Crossfire TA's Avatar
Can you get some more shots of that hood? It seems to have different lines then the rest of the cowl hoods, almost like a 4th gen sunoco hood...
Old Dec 13, 2009 | 03:06 PM
  #304
Stephen's Avatar
Car: 87 GTA
FYI...The "4th gen Sunoco hood" is merely a COPY of the 3rd gen Jongbloed hood.
Old Dec 13, 2009 | 07:05 PM
  #305
If it is it's funny because they're a different size, different shape and the Jongbloed hood has a center ridge that the sunoco doesn't.
The thing that you were calling a Pontiac Jongbloed hood looked a bit like a cross between the camaro Jongbloed and the pontiac IMCA hood... nothing like a Sunoco or like this hood. It either needed to be smaller or have sharper, more defined lines to look like much more than a blob on a pontiac hood.
This hood has a smaller cowl, which I like, but has the center ridge which I'm non thrilled about, but it's hard to tell what shape it really is from those pics, they're sort of taken too close and from angles that it's hard to tell what the real lines are like. In my case a little bit of extra clearance for the engine is OK (I'll use it if I have it but don't _need_ it), but that's not why I'm looking for an aftermarket hood, it's to specifically better manage airflow which noone seems to get (or if they do they do not understand how to accomplish it), so I'm looking for specific shapes that can be modified for what I want without becoming too obnoxious by the time I'm done with it.
Old Dec 13, 2009 | 07:15 PM
  #306
Stephen's Avatar
Car: 87 GTA
Jongbloed hoods follow the stock creases in the hood.
Old Dec 14, 2009 | 10:06 AM
  #307
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
Originally Posted by MärkJ
Yeah no wories, dude.
Image snip....................
These are pretty much all the pics I have of it post paint job. Still waiting for the sun to make an appearance before I can get some decent ones but you know what England's like where the sun's concerned.
What is up with your front marker/turn signal lamps?
Old Dec 14, 2009 | 10:07 AM
  #308
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
GM REd Jewel Tintcoat
Originally Posted by New2Chevy
Here is a slideshow of my old Camaro that I got painted with GM Red Jewel Tintcoat. You have to click the image below and then click "Camaro Finally Finished!" in the new window, to view all the images in the slideshow. It is an 06 and up color, I believe, and I saw it on an 06 Envoy and loved it.
Old Dec 14, 2009 | 12:31 PM
  #309
t5535's Avatar
Car: 87 Trans Am
Transmission: 700r
Ok do you have any pics of this hood from the inside? Does it give you more room for carb air cleaner? O, and where can I got one? this is kinda the same style that I was gonna fabricate for mine. I wanted to leave the vents in it.
Old Dec 14, 2009 | 01:14 PM
  #310
Stephen's Avatar
Car: 87 GTA
Sorry no pics. I never bothered to Photoshop a bottom side view, of the hood that nobody makes. You can only get it from my computer....
Closest thing around, is FYRCHKN's home-grown cut & welded steel hood.
https://www.thirdgen.org/forums/fabr...tor-build.html
Old Dec 14, 2009 | 05:17 PM
  #311
t5535's Avatar
Car: 87 Trans Am
Transmission: 700r
That is the same idea I had for mine. I was gonna make it myself. but I am wondering about the cross members on the hood. I need the room for carb and air cleaner and I am worried about cutting the supports on the hood. I also planed on making the vents in the front active. I guess I could photoshop the back side of one if I could get a good pic of the back side of the hood. I am pretty good with photoshop.
Old Dec 15, 2009 | 07:23 AM
  #312
t5535's Avatar
Car: 87 Trans Am
Transmission: 700r
looks like its time to get out the die grinder and welder and make one. I am gonna head to the junkyard today and find a spair hood to work on!
Old Dec 17, 2009 | 11:58 PM
  #313
ddemetrius456's Avatar
paint it purple with a glitter coat over it!!!
________________
Wonderbra
Old Dec 18, 2009 | 11:58 AM
  #314
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
<a target="_blank" href="http://www.slide.com/s/qSVo50607z_8E...rer=hlnk"><img src="http://widget.slide.com/rdr/1/1/2/S/...niqJXTHoyv.jpg" border="0" alt="Host unlimited photos at slide.com for FREE!" title="Host unlimited photos at slide.com for FREE!" /></a>
This color is great, in my opinion.
Old Dec 20, 2009 | 11:04 AM
  #315
t5535's Avatar
Car: 87 Trans Am
Transmission: 700r
Thats the color that I am gonna go with GM Red Jewel Tintcoat. But from what I understand it is a 3 part paint. a base a mid and a clear. Is there a paint code for it?
Old Dec 22, 2009 | 02:45 PM
  #316
88iroctpi305's Avatar
Car: 1988 Camaro IROC-Z and 91 Z28
Engine: 305 TPI and 350 TPI
Axle/Gears: unsure of ratio but POSI (:
redish brown. i dunno exactly what color or where. i just got the car.
Old Dec 29, 2009 | 09:59 AM
  #317
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Anyone got pics of paint code 9535?? My 89 IROC is or used to be this color but I'd like to see what it looked like new. Flame or Victory Red.
Old Jan 2, 2010 | 03:03 AM
  #318
timothy1238's Avatar
Red will the best color and even silver is pretty great
_________
Limo Hire
Old Jan 29, 2010 | 01:16 AM
  #319
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Just finished mine today, and i am not a painter....
Attached Thumbnails What Color to Paint!-double-160.jpg   What Color to Paint!-double-161.jpg   What Color to Paint!-double-165.jpg
Old Jan 29, 2010 | 09:43 AM
  #320
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Bump?
Old Jan 29, 2010 | 10:32 AM
  #321
Timmie's Avatar
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
probably somethnig like this
Old Jan 29, 2010 | 10:39 AM
  #322
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Mine is not a red like that, More a maroon/bronze??
Old Mar 3, 2010 | 06:23 PM
  #323
puma1552's Avatar
My car is the factory color, Maui Blue Metallic I believe (Code 23?). It is a 1990 model, but it was repainted in 1992 after a hail storm (presumably there was no paintless dent repair back in the day...) otherwise it would still be wearing factory paint.
Love it to death, and had it 11 years, second owner, since I was 15. I would absolutely love to strip the car down to metal and rebuild the entire thing with the same paint job, just a lot deeper.
Old Mar 30, 2010 | 08:11 PM
  #324
oakleys's Avatar
I just finished up my mettalic orange on the 87. Turned out pretty well...was going to put white stripes but I decided against it. Now its on to tinting windows and deciding if i want to alter the wheels or not. As far as body alterations...I did the hood, new fenders, put a 2" lift on the back and stuck some fairly large tires under the back. Gives it a pretty good look I think
Old Mar 30, 2010 | 10:40 PM
  #325
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Looks great! I can't wait to get my car painted!
Old Mar 30, 2010 | 10:42 PM
  #326
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
I still think GM REd Jewel Tintcoat is a great color.
Old May 30, 2010 | 06:21 PM
  #327
tdub197's Avatar
Car: 1992 RS 25th Anniversary Edition
Engine: 192
Hey, my names taylor, im 17 and i recently just bought my first car, a blue 1992 rs. the funny thing is, i bought the car for cheap and was planning on selling it for alot more than my purchase price, but i ended up falling in love with it and im working my butt off to restore it. there was tons of rust on the hood and roof, so ive sanded and cleaned all that off, and its primed and ready for paint. the only problem is is that ive been stressing over what color i should paint it. so i have a very serious question, and im just looking for honest opinions and unbiased male opinions, i had a fun thought in my mind, what about painting it pink! and i know some people might not think its a good idea at all, but just open your mind for one second and picture it. me and my dad talked about doing it two-toned, pink on the bottom half and black on the top? with dark tint and maybe even pink and black rims. or even all black with pink rally stripes? i just want to hear some feedback on how you guys think that would look. ive been looking for a photo editor to get a visual but im not too good at that kind of stuff. i know it sounds outrageous but this is my first car and i have worked so hard on trying to bring this car back to life, so i want the car to be mine and original. ive never seen a pink 92 camaro yet so i think it would be pretty awesome what do yall think?
Old Jun 1, 2010 | 01:49 AM
  #328
screamnchickn's Avatar
Hey Taylor, just wanted to maybe comment on your color choices. I don't think its too bad depending on what shade of pink, I mean I don't think that a hot pink would be the best color, but perhaps something of a purple/pink (dark pink) I have a good shade that I think would be pretty bad%$!, lol it's my fingernail polish and my husband pointed it out while reading your thought. But I seen a shirt once that said only real men where pink, and I think a camaro can pull off pink
Old Jun 1, 2010 | 07:18 AM
  #329
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I have a 2004 Dodge SRT-4 that I bought new in 2005. I was originally trying to get an "Orange Blast" one, but after learning that the 2004 had 70,000 mile warranties and the 2005 had only a 36,000 mile warranty, I decided on a blue one.
I've never heard of anyone else (dealers) offering this, but Dodge offers ANY late model factory paint colors in spray can form. They are identical to the factory colors, just offered in simple spray can form. I bought 2 when I painted my side mirrors body color. It worked great!
Anyway, I ordered a can of Orange Blast (code PVK) from my dealer today. I'm basically just going to be testing at this point (spraying a small panel) to see roughly how I like the color in different lights. It may very well be the color I paint my 91Z28.
[edit]
Teaser pic of the color:
I like the GM orange offerings ok, but honestly, they're all too dark for me. They always look clay-red orange in low light.
Old Jun 23, 2010 | 07:35 AM
  #330
1st91firebird's Avatar
Car: 1991 firebird
Engine: 3.1 v6
yeah im 2 goning my 91 firebird a black on top and a red rock matallic on the bottom
Old Jun 23, 2010 | 07:44 AM
  #331
Car: 1991 firebird
Engine: 3.1 v6
[quote=1st91firebird;4587641]yeah im 2 goning my 91 firebird a black on top and a red rock matallic on the bottomoh yeah its also going to be a silver pin strip down the side where the 2 colors meet.What do yall think of this idea if any other ideas please share
Old Jun 23, 2010 | 08:04 AM
  #332
Car: 1991 firebird
Engine: 3.1 v6
hey man im 17 and i just bought a 91 firebird for 200 dollars and it runs and has a little rust. the man was just trying 2 get it out of his yard.i thought was going 2 do the same as u but i fell im love with my car myself.now that i got it ready for inspection now me and my dad are going to paint it black on top and a red rock matallic on the bottom with a silver pin strip going down the side where the 2 colors meet.your idea sound pretty cool i could see those colors together. it will look sharp as long as u dont do just a plan pink car.Good luck with your car hope turns out the way u want it to.
Old Jul 29, 2010 | 09:03 PM
  #333
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
I am in the process of fixing rust holes on mine. Decided to paint the whole thing primer black until I can get a paint job. I used a Duplicolor primer called Hot Rod Black. I'm kinda digging it. Call me lame but I'm thinking of just slapping some clear coat over the Hot Rod Black primer and leaving it at that.
Old Aug 15, 2010 | 11:10 PM
  #334
LeftyGuitar91's Avatar
Car: 1991 Firebird Formula
Engine: 5.7 V8
Axle/Gears: Richmond 3.73
I've got a white 91 formula and I have been looking around for a new color to paint it and nothing catches my eye like an electric blue. I'm leaning towards that with new black decals. Should look incredible.
Old Sep 11, 2010 | 12:15 PM
  #335
transamws6's Avatar
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
Originally Posted by 84RIceEater
heres a better pic
i think im in love with that color.....wats the color code?
Old Sep 11, 2010 | 12:42 PM
  #336
cdoyle's Avatar
Originally Posted by bigdavesiroc
i like it. when i was younger those were my favorite wheels. looks good. here is an updated pics of mine.
I'm really liking this, do you have any pics of it outside?
Old Sep 18, 2010 | 03:12 PM
  #337
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
I am about to have my TA painted and will need to know some more about it before I can proceed. I plan to paint white (could use suggestions) and use a red clear pearl over it. I guess thats how it works. I want a red reflection in the paint over the white. Any recommendations for paint colors types and methods would be greatly appreciated. Pictures before and after will then be posted.
Old Oct 1, 2010 | 12:45 AM
  #338
yarby's Avatar
Car: 92 convertible camaro RS
Engine: 355
That is a gorgeous color. I have always wondered how good that orange with black stripes would look and man thats the color. sweet ride!!!
Old Oct 1, 2010 | 12:46 AM
  #339
yarby's Avatar
Engine: 355
Orange88 That is a gorgeous color. I have always wondered how good that orange with black stripes would look and man thats the color. sweet ride!!![/quote]
Old Oct 1, 2010 | 06:23 AM
  #340
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Well, a year later, but better late than never right?
It's a hardwood 2 or 3" cowl. I like the fact it follows the original body lines, and right now, below it sits a carbed motor, with a victor jr intake, 1" spacer, and 4150 carb - standard size open elements clears by about an inch at the forward edge of the aircleaner. Yeah, thats all because of the amount of slope on the front ends of firebirds.
It's 100% open underneeth to the back of the cowl. At somepoint, provided I hang onto the car I plan to make a nice sheet aluminum piece that will seal the aircleaner off to the cowl.
Old Oct 1, 2010 | 10:48 PM
  #341
tahoelt's Avatar
Car: 82 camaro berlinetta
Engine: carbed 305
did all the work my self, had a co-worker spray it for me. stripped it to steel, new quarters, fenders, lower door skins, and front bumper. took 4 months after work from start to finish. paint code CSO(nissan color)
Old Oct 11, 2010 | 04:43 PM
  #342
TheStangPoacher's Avatar
Car: 1969 Chevelle SS
Engine: ZZ 502
Transmission: TH400
Axle/Gears: 12 bolt / 3:73 gears
wasnt your camaro in hot rod or car craft I swear I've seen it in a mag before i think it was a twin turbo 350 camaro
Old Oct 12, 2010 | 12:11 AM
  #343
tahoelt's Avatar
Engine: carbed 305
No it hasn't been in any mags before.... And no there's no twin turbo 350....just has a 305 with a couple mods to it. I wish it was in one of those mags and had that motor but who knows maybe one day it will happen....the motor part that is....lol
Old Oct 21, 2010 | 09:19 AM
  #344
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
how do you guys decide what color to paint your cars? like im stuck between 4 colors. white, red, satin black, or regular black and i just cant choose....
Old Oct 21, 2010 | 09:30 AM
  #345
Stephen's Avatar
Car: 87 GTA
Just remember that if your going to a different color than what your car rolled off the assembly line with and spending the extra $$ to get the door jambs painted, the under hood area will still be the stock color. So unless you start with a black car, the under hood area will look funny. Been there, done that & hated opening the hood.
Old Oct 21, 2010 | 02:14 PM
  #346
Engine: V8 305 TPI
yea i guess ill keep it red then, thanks bro.
Old Oct 25, 2010 | 06:57 AM
  #347
rich5's Avatar
Car: 91 camaro RS
Fresh out of the shop yesterday is a burnt orande metallic with a bit of red. its ppg paint, sprayed by my father and unfortunatly it was the most expensive paint i have ever used but looks awsome.
Old Oct 27, 2010 | 03:01 PM
  #348
RussM's Avatar
Car: 1985 Z28 Copper
Engine: GM performance 350
Transmission: 5 speed manual
Here's an original copper/russet /85 z28... a one year color. I think there were only about 500 Copper z28 5-speeds. I made this web portfolio special for this forum, so you can see the car from many angles. Hope this helps.
http://www.mcneillyconsulting.viewwo...sellfolio.html
Old Oct 27, 2010 | 07:56 PM
  #349
Engine: V8 305 TPI
you are lucky to have a rare iroc in my opinion that is rare. question for you, on your web site under the slide show (got under and in) on the last picture it shows you rebuilt the doorpanels, where did you buy that rubber piece that clips to the panel, mine could use new ones
Old Oct 28, 2010 | 06:36 AM
  #350
RussM's Avatar
they came with the car... If you go to the junkyard, there probably are some on some cars.
