Where to find new t-top center bars?
I've seen them on thirdgenresource (yeah right, like I'm going to buy from them again) and occassionally on ebay, but does anyone else carry them? I heard that 1AAuto does, but I couldn't find them on their site.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i got one off ebay, it was brand new gm original. so that was cool even if it doesn;t matter. there were some used ones listed also. did you chack hawks?
OK, I talked to Hawks and they do have it in stock, and placed a link to it on their website.
http://www.hawksthirdgenparts.com/in...?v=1&pid=21280
They certainly went out of their way on a simple question. The girl on the phone sounded cute, too.
Car: 89 TTA, G8 ST, 57 Chev & 77 Bird
Engine: 3.8 Turbo
T-top center panel
They're also simply orderable at your local GM Dealer.. any GM dealer will get it in for you.. This is the part # 20192907. Make sure you reseal it REAL WELL all around the base of it and under it when re-installing & check for rust holes that might allow for water drainage to occur inside the front of the turret shell.
Car: 1982 Z28 Indy Pace Car
Engine: 305 LU5
I'm also looking for a t-top bar. The one listed at Hawks says it's for 85-92. I have an 82. Does anyone know what makes the 82-84 t-top bars different?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: T-top center panel
10219043 is for 86-92. $113.78 (same place)
Engine: 305 LU5
I looked at the GM parts catalog. It shows the change occuring in 85. If the ttops have the plastic trip around the edges you use the earlier design. If the ttops don't have the plastic trim you use the later design.
There must be something different (spacer or felt strip) that makes up for the ttop plastic trim not being installed on the later design.
I've removed the plastic trim pieces from my ttops (they were shot). Sounds like I need the later design.
Thanks for the help.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
