Repairing gfx
Old Oct 31, 2004 | 09:31 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
Repairing gfx
what should you use to repair gfx mounting tabs that are cracking....bondo??? or what methods work?
I just bought some 91-92 camaro aero gfx and one mounting tab has completely come off maybe in transit i dunno and two others have cracks 1/2 way across the tabs and i was wondering if bondo could fix it or maybe some kind of fiberglass glue?
Please let me know how to fix this
Old Oct 31, 2004 | 05:17 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
depends on which construction the gfx is. for the side peices with fiberglass, i used a bondo fiberglass kit to patch it all up. then i just redrilled all the holes. just be sure your mounting surface is still original in location so you don't mess with the mounting angles, do the repair on the down side of the panel.(ground side)
on the front where it is that urathane rubber stuff, there are some specfic product for the repair of those. i belive one is made by fusor, they do have a kit for repairing the tabs on the front bumpers that are the rubber stuff looks like a nice product and easy to use.
jeff
Old Oct 31, 2004 | 06:49 PM
Car: 1989 GTA
the tabs are the mounting tabs on the rocker panels actually its just on one of the rocker panels like two need to be repaired so bondo should do the trick on it...are you sure these are fiberglass they are kinda bendy
Old Oct 31, 2004 | 07:25 PM
JeffW's Avatar
Engine: 305 tpi LB9
on my z28 they were fiberglass, not sure on the gta. scratch a piece of it and you should be able to see what the material is. if it is bendy it may not be fiberglass as mine are quite ridgid.
Old Nov 2, 2004 | 12:44 AM
Car: 1989 GTA
i do believe they are a plastic of some kind they are not hard like fiberglass...i need some more opinions and info on this...please respond if you have any suggestions
Old Nov 2, 2004 | 04:55 PM
JeffW's Avatar
Engine: 305 tpi LB9
so is the material the same as the front end of the car? the nose and bumper covers are that urathane plastci stuff that is soft flexable. if that is the case fusor has a tab repair kit that looks really cool. i have a cd with the products on it and how to use them.
this seemed like a real simple process and a good looking end result. do a search on fusor and you should find it out there.
jeff
here ya go maybe someone knows whihc product is the right onw if not i will find my cd and pull up the numbers, it had tab renforcement tape and the adhesive for the repair.
http://www.lord.com/Default.aspx?tabid=1193#1421432
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
