Which cowl induction hoods are open in the back (near the windshield)??
Old Nov 3, 2004 | 12:11 AM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
OK, finally decided on what size cowl I need/am getting, and yet another question arises. I am a gauge ***** simply put. Essentially what I want to do is use the lip on the firewall to mount some gauges and have the cowl hood cover them so to speak. However, some companies like Cervini's close off the rear of the cowl and have little vent looking things in them. This pic is of Rage13's Cervini's hood(hope you don't mind that I stole your pic) so you can see what I mean about the vents.
I want the whole part of that hood open(instead of those vents). Does Harwood have one like that or will end up using something from say Unlimited Products up22.com or Glasstek? Thanks for taking the time to read this, and as always opinions or suggestions are welcome.
Paul Moore
Old Nov 3, 2004 | 12:27 AM
paulmoore's Avatar
Sorry, forgot to attach the picture. Like I said before, this is the type of hood I don't want. I would like for the hood I get to be open in the rear. Thanks, Paul Moore
ARRG.... For some reason it won't let me put up a pic on this thread, sorry.
Old Nov 3, 2004 | 03:40 AM
EvilCartman's Avatar
Car: '82 Z28
Fibreglass can be cut ya know My Harwood 3 inch is closed off in the back with a couple mesh screens letting the air through.
Old Nov 3, 2004 | 06:06 AM
CamDragonZ28's Avatar
Car: 1990 Camaro IROC-Z
My Glasstek 4" has an open induction. Im actually trying to find a filter for it or gonna custom make one.
Old Nov 3, 2004 | 06:56 AM
CrazyHawaiian's Avatar
Car: too many ...
I have a unlimited products hood and its open (thanks to CaysE for that info hehe). Here's a pic where you can kinda see it:
Old Nov 3, 2004 | 11:31 AM
paulmoore's Avatar
Cool deal, so basically I guess that I'll be looking for either the glasstek or the unlimited products hood. In you guys' opinion, which one do you think had better construction or are they about equal? Thanks, Paul Moore
Old Nov 3, 2004 | 01:11 PM
k's89rs's Avatar
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
DO NOT GET AN UNLIMITED PRODUCTS HOOD!!!!!! i got a two and a quarter hood from them and it sucks. one i ordered a FRONT LATCHING hood that would work with my hardware....... left out a tap. couldnt latch it down. had to pin it in the front. which i was trying to avoid in the first place. i called and got my 80 bucks back. the corners were R O U N D not clean cut. the hood was cut too short so there is a half inch gap between by nosepiece and the hood. THERE WERE FREAKIN WAVES IN THE FIBERGLASS that i had to lay 3 coats of bondo on to smooth it out. rough non primered underside. and it took 2.5 months for them to get this "hood" to me. didnt want to sent it back because they were going to charge me shipping.
Old Nov 3, 2004 | 03:49 PM
CaysE's Avatar
Cervini's cowl hoods are also open in the back. I like the overall look of the Unlimited Products hood, but I don't really recommend them for show purposes. The underside is unfinished fiberglass and I think the cowl opening is a bit flimsy. Here's a picture of mine: (thanks transferred to Flrtin1 for the info )
Old Nov 3, 2004 | 05:33 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
I have the Un-limited Products hood which is the 2 1/2" cowl that bolts on to the existing hinges and latch. It is open in the back and yes, the under side of the cowl itself is rough fiberglass. I took a piece of aluminum and attached it to the underside to give it a finished look as well as enclose the cowl to pull the air into the carb. I cut out an opening for the air cleaner to sit in the cowl with a K+N filter assembly with their X-Steam top. Works great, and I like the looks of the hood. I have no complaints on my hood.
Old Nov 3, 2004 | 10:59 PM
k's89rs's Avatar
well good deal man im glad you got a hood from them that is worth something. i must have gotten a bad seed
Old Nov 4, 2004 | 06:49 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Unlimited Products hoods suck! I also gotta add my 2 cents on this hood. I have the 2 1/4 cowl hood & mine also took alot of work to get it to sort of fit & look decent. I also agree that the hood seems very flimsy around the open cowl area & it flexed alot while driving on the freeway. So I ended up reinforcing the area with sheet metal & closed up the cowl & added 2 open rectangular holes. The hood doesn't flex as much now.
Old Nov 4, 2004 | 03:47 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Yes you are right about the cowl flexing in the middle at the back or opening of the cowl. What I did was to make support out of bolt stock to the length needed. I then epoxied a flat washer to the top and bottom. Before I put it on I put a piece of vacum hose around the threads to cover them and give it a finished look, then I glued it into place back about 1-2 inches. Before glueing that in though, I put a flat piece of plastic that I had laying around onto the top section of the underside so that the support piece I made woud set flat and it also strengthened the area of the hood under the cowl where the hood meets the cowl. You could also use aluminum and glue it in place to give that area strength. What I liked about the hood was the cowl came back at an angle to the winshield if you know what I mean. I don't like the ones that go straight up at the back. I've also seen others that at the front of the hood the front leading edge was a square blunt edged, my hood is tapered like the factory hood. Yes the Unlimited Products hood was not perfect but the overall fit was good, I didn't have to do any shaping or such, I just modified some things to give it more strength and to finish off the raw fiberglass side of the cowl. Overall I was pleased.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
