Deathly Driver's door creak!!!
Old Nov 7, 2004 | 10:25 PM
csi1286's Avatar
Car: 91 Camaro RS white w/ T-tops
Engine: original 305TBI 140,000mi
Transmission: automatic (although standard would be preffered)
My driver's side door creak something aweful. It also rubs against the bottom of the jam. hence it hangs from all logical conclusions. I tried loosening the three bolts on the top mounting bracket and lifting the door but no change was noticed. The bottom hinge setup dosent seem too worn out either. Anyone have any experience or ideas before the bottom of my door rubs away!! Thanks.
Old Nov 7, 2004 | 10:27 PM
BLACK ICE's Avatar
Car: 91 RS
Axle/Gears: 10 bolt
Maybe your car is a little tweaked was it in an accident or does it have a pretty healthy motor and no subframe connectors?
Old Nov 7, 2004 | 10:36 PM
csi1286's Avatar
Dont suspect anything like that car has never had an accident.
Old Nov 7, 2004 | 10:45 PM
CaysE's Avatar
Replace the pins and bushings on the upper and lower hinges. Replace the lower hinge, too, if you want.
Door components:
http://www.hawksthirdgenparts.com/do...dow_components
If it still won't close properly after that, get the frame straightened. No matter what you do, get subframe connectors installed.
Spohn SFCs:
http://www.spohn.net/product.cfm?productid=1309
For a quick fix to that annoying squeaking sound, spray the hinges down with White Lithium Grease.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
NiG
Sep 2, 2015 06:54 AM
hepcat620
Exterior Parts Wanted
Aug 30, 2015 07:52 PM
kkirch15
Interior Parts Wanted
Aug 28, 2015 10:03 AM
tecustomz
Aug 16, 2015 02:28 PM
