Question about removing/shaving factory antenna
Old Nov 10, 2004 | 02:30 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I like the 'clean' look of not having an antenna sticking out of the passenger front fender. Anyway, after I get the car ready for paint and stuff, I was thinking about removing it or shaving it if you will. Take the old antenna out, put a metal patch panel over it weld it in and then smooth it out. Only problem is that I like my radio too so how do I get around this? Is there a way to remove the factory antenna, but still have the ability to pick up radio stations? Can a remote antenna be mounted somewhere discretely and unnoticeable? Any opinions/suggestions are welcome. Thanks, Paul Moore
Old Nov 10, 2004 | 07:48 PM
bbk1's Avatar
Car: 87' camaro iroc-z
Engine: rebuilt stock so5
Transmission: auto
y dont u use 1 of those retractable antennas that after and b4 use it moves up and down. save the radio and the body work. Although it is a smaller area it is still annoying.
Old Nov 10, 2004 | 08:01 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
run some antenna wires up the a pillar and under the headliner
Old Nov 10, 2004 | 08:14 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
i had mine shaved a while ago. i havent put the antenna back in the car yet, but when i do im just going to run the stock metal antenna under my dash pad. Many people have put it there and get great reception.
Shave it, it looks 100% cleaner
Attached Thumbnails Question about removing/shaving factory antenna-8.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
