Door Mirror Glass
Old Dec 2, 2004 | 02:41 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Door Mirror Glass
Is it hard to replace the mirror section on door mirror. I am thinking of replacing my driver side mirror section and am wondering is it difficult to take it out. My mirrors are manual so will a mirror from an electric door mirror fit okay.
Thanks.
Old Dec 2, 2004 | 03:08 AM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
on the passenger side is easier to replace the whole mirror,on the driver's side its harder due to the adjustment cable,if you just want to replace the mirror element you'll have to be very careful not to distort the section where the mirror attaches to.
Old Dec 2, 2004 | 04:10 AM
gholian's Avatar
Engine: 2.8 V6
How is the mirror element attached is it with screws or clips of some kind.
Thanks.
Old Dec 7, 2004 | 03:17 AM
gholian's Avatar
Engine: 2.8 V6
Is the mirror element the same on manual and electric mirrors. Is the motor for electric windows in the mirror or in the door.
Old Dec 7, 2004 | 09:47 AM
MNformula350's Avatar
On the manual mirrors the glass and mounting bracket are held in by 3 torx screws (t-10 or 15 i don't recall). the passenger side is cake can be swapped out in like 2-3 minutes. The driver side (as previously stated) has the adjustment cable attached so you will need to remove the piece where the adjuster comes into the interior door panel and remove the flat metal clip that holds it in place, it actually would be easier to remove the whole door panel to fish the cable out wiht the old and in with the new.
And the power mirrors are different.
Old Dec 8, 2004 | 12:37 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
i closed my pass. door once and the damn window just fell off. luckily it didnt break
RyanJB
May 7, 2016 06:23 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tglennon11
Sep 23, 2015 05:30 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
