4thgen dash fuel gauge question
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Sorry I didnt know if i should post it here or the Electronics board. I figured more people on this board would be more helpful.
Im putting a 98 cluster in my dash swap and I have searched but never really found a solution to the 98+ fuel gauge to get working. I know they run off of a different resistance range than ours, but how did you get around that?
Any help would be awesome. I have to get the car running soon. I can't take the cold weather on a motorcycle.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: 4thgen dash fuel gauge question
Car: 1991 Z28
Well I could not get my hands on a 97 cluster. And I rather not have a T/A cluster (I dont like the red lights)
Custom X and others have claimed to have used a 98 cluster but I have not seen how they overcame the problem.
Car: 93 240SX
Engine: LQ9
Car: 1991 Z28
well i switched out the gauge with one from a 90 gauge cluster and put it in. still no worky. when i plug in my sending unit the gauge goes straight to E (no resistance) with both of the gauges. so I think there is a resistor on the circuit board or something?
Car: 93 240SX
Engine: LQ9
The newer gauge senders are 0 empty 250 full, your stock thirdgen sender is 0 to 90, good luck modifying the resistance.
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
If you still looking to get your fuel guage to work, here is how to make the 0-90 fuel guages work in the 98+ clusters. Its buried somewhere in the 13 pages http://www.fiero.nl/forum/Forum1/HTML/023174-10.html
Ghettobird52
Jul 5, 2024 11:18 PM
