how do i fix this peice?
Old Dec 15, 2004 | 06:47 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
im trying to repair this corner of my 92 front spoiler. im gonna v out the crack fill one side with plastic adhesive then when it dries im gonna do the back then finish it up with dura glass. any suggestions??
Old Dec 15, 2004 | 06:57 PM
megaracerx's Avatar
elmers glue.
Old Dec 15, 2004 | 07:29 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
the right way to fix this would be to get it plastic welded and do both sides then i would sand down the front side untill it is flush if you still see imperfecions i would skim coat it with plastic bondo witch is green. for extra support i would put a bit of fiberglass/mat, or bondoon back side.
Old Dec 15, 2004 | 08:12 PM
crazyn8's Avatar
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
3M Makes a flexible plastic 2-part epoxy that repairs urathane plastic. just V-cut your crack and fill with the epoxy. Reinforce the back of teh repair by building it up with extra epoxy. Its an easy fix.
Old Dec 16, 2004 | 07:12 AM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
DO NOT USEBONDOFIBERGLASSORPOLYPUTTY!!!!!!!!!!!!!!!!!!!!!!!
AGAIN!!! I have outlined a repair method please do a search. I have also decided to do a tech article on the subject, that I hope will get a sticky.
This is a foolproof method and WILL NOT FAIL!!!!
armybyrd
Sep 28, 2023 12:16 AM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
