Let's take the guesswork out of plastic repair!!!!!!!
Old Feb 2, 2007 | 07:03 PM
  #51
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
That was just a link to the product page...Sorry if I wasn't clear.
The Plastic repair link is on the left of the page
Old Feb 3, 2007 | 05:39 AM
  #52
83 Crossfire TA's Avatar
They list:
Super Fast AdhesiveFast Urethane Adhesive
Medium Urethane Adhesive
Semi-Rigid Epoxy Adhesive
Here: http://www.evercoat.com/productCategory.aspx?cat=6
Any specific one for what we’re talking about or all of them work well?
Old Feb 3, 2007 | 08:35 AM
  #53
luke-gr's Avatar
I notice there is a Super Fast, Fast, and Medium. I dont think you want the semi-rigid from what Kevin has said here earlier in the thread. Almost sounds to me like the other three are just different work times.....but I could be wrong.
Old Feb 6, 2007 | 05:59 PM
  #54
KEVIN G.'s Avatar
Engine: 305 CARBED
Yeah the medium is ok for what you will normally repair. They are just longer set times.
Old Apr 11, 2007 | 02:14 PM
  #55
rebel1222's Avatar
Car: Looking
Re: Let's take the guesswork out of plastic repair!!!!!!!
Where can this product be purchased at?
Also, I'm getting ready to paint mine, and should I have flex agent put in the paint? due to the plastice front and rear bumpers?
Old Apr 11, 2007 | 08:42 PM
  #56
How about something to make a really small repair without putting myself >$50 in the hole?
Check out this thread:
https://www.thirdgen.org/forums/body...-do-i-fix.html
Old Apr 13, 2007 | 08:35 AM
  #57
rebel1222's Avatar
Car: Looking
Here's my bowtie grill. Should I use the methods described at the begining of this sticky make this repair. You can see how the finish is cracked. I was planning on just filling the cracks with two part epoxy, sanding and painting black the same day the car is painted witht the same paint. Does that sound liek the best course of action with this repair?
Old Apr 15, 2007 | 07:09 PM
  #58
KEVIN G.'s Avatar
Engine: 305 CARBED
https://www.thirdgen.org/forums/bo...-do-i-fix.html (How do I fix this?)
83 Soory I haven't been on in months... That is kind of a tricky spot. You do need to repair the inside as well as the outside on that tear, but it has to be thin enough to allow your retaining bracket ot go in the groove. Just use my method and it will be strong. Use a Popsicle stick on the inside to smooth it around and keep it thin without it gobbing up and restricting the palcement of your bracket.
Rebel, I cant see the damage in that picture. Could you increase the size?
If it's just paint damaged and split, sand it off and prime and paint.
As for the flex...you only need it on the plastic panels.
Old May 21, 2007 | 10:34 AM
  #59
spitstickler's Avatar
Car: 86 IROC (Red on Red)
Engine: 305 tpi
Originally Posted by KEVIN G.
Coat again with a flexible skim coat epoxy made by the same company as your repair material.
Is the flexible skim coat epoxy an item that any paint store should be familiar with? Do you have any product numbers for reference for what you've used in the past? I'm thinking about going the 3M EasySand route.
I also have a question about spider web type cracks in the base plastic. I've started sanding mine down and the these cracks go through all the paint and primer and are clearly evident in the spoiler itself. Do I have to continue sanding until I get them out too? (I'm worried about keeping it even if I have to go that route) Or can I put the 3m easy sand (or equivelent) over the top to seal it and prevent it from cracking the new paint?
Last edited by spitstickler; May 21, 2007 at 02:38 PM. Reason: clarifing question.
Old Jun 7, 2007 | 05:03 PM
  #60
Engine: 305 tpi
Here's a couple of pics of what I'm asking about.
And a closeup
Old May 4, 2008 | 06:31 AM
  #61
duperdave's Avatar
Car: 87 z/28
Engine: 305 tpi
Transmission: auto 700r4
Axle/Gears: not sure 2.73 I think
I have a hole in my front bumper cover can I use this process or is just for cracks.the hole is about 1-1/2 inchs in diameter
Old Dec 22, 2008 | 06:00 PM
  #62
JMR's Avatar
JMR
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
kevin g, the only focus on this tread has been on urethane plastic so my question is what is the proper way to fix abs plastic?
Old Jan 6, 2009 | 10:12 PM
  #63
Dustin Fitch's Avatar
Car: 91 Firebird
Engine: 3.1
hey kevin I noticed you haven't been on in almost 2 years now. You still there?
Old Jan 21, 2009 | 11:45 AM
  #64
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
How would you repair a plastic thread?
The one in my spoiler are old and fragile. I was thinking of cleaning them, then glue it with a PU glue. Screw inside it with grease/oil on the screw.
What do you think?
Edit: I am thinking that it might be ABS and not Urethane. Correct me if I am wrong.
Old Feb 2, 2009 | 04:54 AM
  #65
ahhwataday's Avatar
Car: 98 Camaro 00 lifted silverado
Great thread. Been around a while I think that ppl should post what they need, projects completed, What they have used.
I have a crack on an 86 Camaro ground effect. I will post pics and do reasearch to find out what works and doesnt.
Old Mar 8, 2009 | 03:05 AM
  #66
ahhwataday's Avatar
Check out the vids from 3m
http://solutions.3m.com/wps/portal/3...e-Body-Repair/
Old Apr 20, 2009 | 11:17 AM
  #67
Slouch's Avatar
I really like the patern in the lower left corner... I know its cracks but it would be kickass if you could simulate that effect into a paintjob.
I have been having a hell of a time trying to repair the new front lip I got... This is not as easy as you think.
Old May 9, 2009 | 01:27 PM
  #68
tic_tac's Avatar
Car: 1989 Camaro RS
Two questions, first: would it be possible to fix the two cracks? and if so what would the be the best way to go about fixing them? The cracks are in the front clip and on the passenger side ground effect. Pictures attached.
Thanks for any help.
Old Jul 25, 2009 | 11:52 PM
  #69
Hartmann's Avatar
Bump, could this process be used on a corner of a front bumper? If so how would I go about getting it to stay in a good shape while the product held/cured, instead of breaking apart?
Old Jul 29, 2009 | 12:07 AM
  #70
ahhwataday's Avatar
If you look at some of the videos within the link i posted, They use tape. Thats what i use and then sand down any imperfections. If you are able, Please post pics. Im sure someone with more experience will be able to help you.
Old Aug 27, 2009 | 12:05 PM
  #71
96LT4c4's Avatar
Car: 99 HOSS 6 Speed
http://www.vetteweb.com/tech/vemp_08...air/index.html
Old Feb 3, 2010 | 06:41 PM
  #72
bikrron's Avatar
i know this thread started a whie ago, but i am trying to come up with a way to repair my wraparound spoiler(even if only for a while). would the 3m products work wellfor filling the cracks in the side corners? i have used it in repairing bumper covers with the sheet of reinforcment behind the repair and it works great but wasnt sure if it would fill very well on a spoiler. the only other problem the spoiler has is the paint is cracked on top. looks like someone didnt add flex agent when painting then some moron sat on thspoiler and the paint cracked(only cracked in the butt area on either side. going down through the thread it sounds like the 3m products should work at least for a while, just trying to buy some time before having to do the inevitible and spending a bunch of mone for a new one. who knows, maybe someone will have them cheaper.
Old Feb 3, 2010 | 09:48 PM
  #73
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
id bondo, but a new spoiler is more favorable, a bunch of money is kinda overrated, id try the wanted section
Old Mar 19, 2010 | 08:48 PM
  #74
h_worker's Avatar
hi,i have a86 camaro and a split has started on the front nose cone on left hand upper front side where top of fender meets nose cone ,next to head light and is now getting longer how can i fix it?its at top of front fender and when nose cone flexes it gets longer and paint is peeling off.please help.
Old Mar 25, 2010 | 06:19 AM
  #75
tcassaday's Avatar
Car: 87 Firebird and 93 Accord
Engine: Bird has a 355 ready to be put in
Transmission: TH-350
Axle/Gears: stock 3.43
the bumper on my 87 firebird is cracked about 4 inches from the top all the way to the bottom and the crack runs along the rubber insert in the bumper. it is a verticle crack and i was wondering if it is worth it to repair it or should i just replace it
Old Sep 16, 2010 | 10:13 AM
  #76
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
My spoiler on my GTA broke at the area that runs along side of the glass about six in. from the narrow end would this fix work in my case.
Old Sep 23, 2010 | 12:16 AM
  #77
noel8877's Avatar
Anyone know were to get a new 92 chin spoiler. mine has a crack in the corner and im sick of it recracking everytime it get brushed on a peble. I want to see if i can get a brand new one.
________________________________________
Soundproofing
Sound Proofing
Old Sep 22, 2011 | 04:46 AM
  #78
84BirdinOK's Avatar
nice topic, I have several holes to fill in my 92 bumper cover, I'll post pics of my project.
Old Apr 15, 2012 | 10:54 PM
  #79
jckn84z's Avatar
Car: 84 Z28
Engine: 305 for now
Transmission: 350
so... i started a new post looking for help with my bumper repair than i found this one. so, can and how do i fix this? (see pics)
Attached Thumbnails Let's take the guesswork out of plastic repair!!!!!!!-bumper-1.jpg   Let's take the guesswork out of plastic repair!!!!!!!-bumper-2.jpg   Let's take the guesswork out of plastic repair!!!!!!!-chin.jpg
Old Apr 20, 2012 | 10:10 AM
  #80
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
WTF???
Nobody mentioned duct tape and rattle cans.
Just kidding ... great info Kevin.
The PO of my car thought it would be amusing to enter driveways at the fastest speed possible without lising control. Then some lowered import steaming pile of **** decided to t-bone me so the drivers door was trashed along with the quarter and the ground efx. Gonna fix the ground efx and get the door and quarter replaced . Gonna also delete the nose emblem then get it painted.
this article will help with the ground efx.
Old Nov 7, 2012 | 11:29 PM
  #81
FireTurkey's Avatar
Originally Posted by Randy82WS7
delete,, since i am apparently invisible in here.,...
a bit self centered I think lots of posts people can miss things no need for a 8 year old tantrum
Posted from Thirdgen.org App for Android
Old Jul 26, 2014 | 11:26 PM
  #82
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Or you could utilize plastic welding.
Old Jun 13, 2015 | 07:39 AM
  #83
snakeshooter's Avatar
I want to join a camaro lower half front cover to a firebird upper half cover. I have seen pics of it where you cut the front covers in half then rejoin them. My question is better to weld or will epoxy hold up?
Old Jun 16, 2015 | 09:17 PM
  #84
Jb 1984 camaro's Avatar
Car: 1984 camaro
Engine: after market 305
Transmission: 3 speed auto
I'm a big believer in Bondo. I use it to fill holes, fix dents and even brackets. The front end was sticking out of my car due to a broken bracket. I just put a scoop of bondo between the front end and the fender, put pressure on it for about fifteen mins, then wham bam thank you ma'am. Good as new
Old Jan 19, 2017 | 10:00 AM
  #85
jworks's Avatar
Car: 1987 Trans am GTA
Engine: 5.7 liter
so, since were talking about plastic/ fiberglass repair do you think the bumper in the picture should be repaired or replaced? I was told by a paint/ body (emphasis on paint being his first choice of work) that I would be better off replacing it. as far as I can tell it doesn't have any cracks in it, just the messed up paint.
Old Jan 19, 2017 | 06:01 PM
  #86
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
What could you possibly have to lose by attempting the repair yourself?
You can't make it look worse unless you try to do the whole job with a chainsaw, and paint thrown from a trebouchet.
These are our hobby cars. We can go as slow as we need to to deal with the small issues. Not like the hurry-up-to-the-next-job professional shops that look at our cars and run away with their hair on fire.
If you can repaint a bicycle without it looking a complete mess, you can probably do a decent job filling the damage, and repainting the bumper on a third gen Camaro.
Old Jan 27, 2017 | 02:13 PM
  #87
jworks's Avatar
Engine: 5.7 liter
Well, W.e.g, you've inspired me lol. in an attempt to keep as much of the original car in tact as possible I've started sanding down the bumper today (after finishing the removal of 20 yr old tint on the back windshield but that's another story completly) but I do have a question, should I completly strip the bumper or just sand down the really badly cracked spots and use a filler to re-level it?
Old Jan 30, 2018 | 10:23 PM
  #88
Corey.white's Avatar
What online website would be the best to get body party for a firebird formula, because the ground effects on front of the you're are obliterated
Old Jan 30, 2018 | 10:53 PM
  #89
Drew's Avatar
formula dont have ground effects.
Old Jan 31, 2020 | 06:35 PM
  #90
KEVIN G.'s Avatar
Engine: 305 CARBED
Guys, Sorry for the long hiatus, I finally got my account back. I came to North Carolina to make a career move, and lost access to my account. I have been meaning to PM the owners of ThirdGen.org for years, but never did.
I finally contacted them for a terrible reason. Sadly I had to let my beautiful Aero go...Mice got to the engine harness and the interior, as well as behind the dash. I was heartbroken. NC is an inspection state, and the car would not pass without additional work. so I let it sit, and that's what did it in. I had that car stored in the winters in Michigan for 20 years. Each year I got it out in the spring/summer without so much as a turd...A year after bringing it down here, it developed an engine miss, and several things were not working that I know did not fail out of the blue. After some diag...all the evidence I needed was right there.
I will try to help out once in a while, as I may pop in, but right now...I'm too bummed when I look at some of your beautiful cars.
In the next few days/weeks I will be listing some of the parts I have left, in the classified section. I had re-registered a couple months ago in an alternate name, to move some of this stuff...and found a member that needed the hatch shade. We worked a deal, and I think he's very happy.
I am honest about any of the parts I have...and am happy to help another member.
Let's keep 'em alive guys....
MrPackstin
Oct 25, 2017 08:09 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
