Help! broke a stud!
Old Dec 17, 2004 | 11:36 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Help! broke a stud!
Ok, dumb *** me didnt check to make sure the ratchet wrench was still set for loosening after taking out the passenger seat so i tightened the 1st nut on the driver side and snapped the sumbitch off! What can i do to fix this? Welding a new stud in would probaby the best option. but i am not really in a place that can support the amps that a welder needs . Any other options? Could I drill it out and put a bolt through there?
Old Dec 17, 2004 | 11:51 AM
laiky's Avatar
cut the stud off flush with the floor, drill it out and replace it with a grade 8 bolt and large washer. once tight i would tack weld the bolt to the washer and the washer to the floor for future convienience. Make sure to use a strong bolt!!!
Old Dec 17, 2004 | 12:54 PM
i figured thats what i needed to do. thanks.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
