fiberglass hood question
Old Dec 19, 2004 | 05:03 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
I have an 84 Z28 and am putting a gm glass hood ( a 82 I think )on and will be cutting a hole for the air cleaner and then a cowl scoop. There is two ribs that would have run just outside the aircleaner. The center portion looks like it is removeable and mine doesn't have anything. Can anyone help me out. A pic would be outstanding.
thanks
Old Dec 19, 2004 | 05:10 PM
conlinj's Avatar
in stead of meesing up a rare factory fibberglass hood why not get a used aftermarket one??? I got mine for 200 bucks... Just a thought
-Jim
Old Dec 19, 2004 | 05:37 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
I dunno im confused but i did this to the stock hood..i should have glassed it.. but i used filler!!! : ( i see tiny cracks under the paint but hard to notice i spent hours and hours.. just not worth it.. rather have paid the 400$ for a bolt on 4inch
Old Dec 19, 2004 | 08:32 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Thats because the factory hoods are no ordinary fiberglass i belive they call it CNC.Same type of glass materials found on fiero hoods and trunk lids.You need a special type of bond agent when molding to it.I did a patch once that turned out nice but I took a screw driver and rippled at the hood until all the "fethers" were poping up,i then used long strand fiber glass filler.Hours and hours of work get the aftermarket
Old Dec 20, 2004 | 02:40 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Close, it's SMC or sheet molded compound.
Old Dec 20, 2004 | 10:46 AM
BOTLFED's Avatar
I just used fiberglass resin and a little bit of mat to attach an aftermarket fiberglass cowl, although the cowl is severely modded.. Lengthend 12"s and raised 1.5"s... It fits nicely..
Cheers,
Old Dec 21, 2004 | 12:40 AM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
We cut a hole in ours and bolted on a mustang scoop. No molding involved and it fit perfectly....
Old Dec 21, 2004 | 12:45 AM
Grr, let's try this again....
Top view:
:edit: I give up for now. Look at the car in the back of my sig. If you want to see more pics I'll host them and link to them later....
Old Dec 21, 2004 | 04:24 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Damn that is bright yellow i likes sorry for the thread hi-jack
Old Dec 21, 2004 | 11:30 AM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Thanks for all the ideas guys. I am planning on bolting mine one. There is serveral cars in my area that have done it and used quality fasteners and it looks pretty good and easy. My original question was about the removeable stringers on the underside of a GM fiberglass hood. I just wanted to know what the things looked like as I might make something up to add a little strength in the area that the hole will be cut.
Old Dec 22, 2004 | 12:51 AM
Don't worry about it, we cut the hole and didn't do anything else. It's been like that for three years no with no issues...
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
