floor pans????
Old Dec 27, 2004 | 05:40 PM
gridley17's Avatar
Car: 1990 camaro rs/89 firebird
Engine: v6
floor pans????
hey i just bought a 1990 camaro for 400 bucks the only thing wrong with it is there is a hole in the floor. Ive been lookin for replacement floor pans but i havent had any luck finding if anyone knows were i could find some can ya plz tell me thanks...... gridley
Old Dec 27, 2004 | 05:47 PM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
Classic Industries has them new for about $200. Search in the category sheet metal & body parts and the sub category floor pans and choose your year. You could also just remove the section you need from a junked car and have it welded in place...or just have sheetmetal welded in place if the hole isn't too big.
Old Dec 27, 2004 | 06:55 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
i helped do this over the summer in a friends 91' RS, it was prety pitiful how much had rusted out, all we ended up doing was buying good sheetmetal at home depot and cutting and grinding then welding it in place, worked fine.
and if you just have one hole, chances are its worse then that, we has most of teh carpet out and it was nuts how much floor we ended up haveing to replace,
Old Dec 27, 2004 | 08:31 PM
Spdfrk1990's Avatar
Do you have all the carpet out? If it is only one hole just patch it.
Old Dec 28, 2004 | 07:08 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
im in the same boat, i need a rusted floor plan replaced, about 5 x 8" ......
Old Dec 28, 2004 | 07:11 AM
Spdfrk1990's Avatar
Thats kinda of a big hole when you patch a big hole you lose the original shape of the floor pan so depending on where it is and how big it is you might want to go with a new pan.
Old Dec 28, 2004 | 07:18 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can i just have someone cut a peice about 5 x 8" and weld it in place??????
Old Dec 28, 2004 | 07:28 AM
Spdfrk1990's Avatar
Do you have a picture of it you could do that but depending on where it is like i said you would lose the contour of the stock panel they have ridges in them. It would work for a daily driver or somethin that isnt going to be a show car.
Old Dec 28, 2004 | 07:31 AM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
it will be covered with carpet and noise insulation ( i think its cld duramax..)
Old Dec 28, 2004 | 08:00 AM
Spdfrk1990's Avatar
You will still have to do something about the underside is what im talking about.
Old Dec 29, 2004 | 10:13 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
Fiberglass!
I had this problem with my car.
First, I removed the entire interior of the car (Actually I did this for welding in the SFC's).
Second, I checked everything else that looked rusty. I only found one place that was rusted through and that was on the driver's side just about where my left foot would normally rest. I would almost bet money that yours is rusted in the same place...
Third, I took a steel brush and cleaned most ( but not all) of the rust from the rusty areas.
Fourth, I hit all the rusty areas with rust converter. It's cool stuff it chemically reacts with the rusted metal, I believe it removes the oxygen from the area? Anyway, it seals the rust up and converts it to a "Primer."
Fifth, I patched the rust through area with fiberglass. It was amazingly easy to work with and it created a very strong seal over the rusted through area.
Sixth, I coated the entire inside of the car with undercoating to seal the metal from oxidation and to deaden noise.
After doing all that I put the interior back in the car and went for a nice long drive to an establishment that served adult beverages...
Speedy
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LC2 TECH
Oct 13, 2015 11:53 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
