Question on 4th gen console swap (Read Faq)
Old Dec 29, 2004 | 12:04 AM
firefrombelow's Avatar
Ok, I was wondering about the fact. It says that the 93-96 T/A had the single cup holder. So, I want to know, is it ONLY the 93-96 T/A that has this? What about the 93-96 Firebird(V6)/Formula or Camaro(V6 or V8)?
Thanks.
Old Dec 29, 2004 | 03:33 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
don't know about the maros but the firebird, formula, and ta will all have the same cup holder. If you want the 4 cupholder setup, you need a 98+ unit.
Old Dec 29, 2004 | 09:09 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Actually, you want the 97+ console if you want the four cupholders.
The earlier firebird console has one, but it is useless. The 93-96 firebirds all had the same console.
The earlier camaro consoles are useless for refittment into a thirdgen. They had the goofy tape rack right where the radio & a/c area is on a thirdgen. Hope this helps!
Here's mine, it's a 98 console.
Old Dec 29, 2004 | 02:46 PM
Thanks for your responses guys! Im interested in the SINGLE cup holder.
Old Dec 29, 2004 | 05:45 PM
85f-bird's Avatar
Engine: 2.8L, LS1
don't get too interested buddy, it's a pointless cupholder... trust me, i don't know who was designing back @ GM, but they really did a ****-poor job on the engineering of it....
I've got a 97+ console (thanks for the correction on the year, thought they came w/ the ls1s, but guess they were just before em) and it works awesome...unfortunately, i've got a 96 dash, and as a result, the console left a gap, so i had to switch to the early model console, until i can fine a good 98+ dash, at which point things will be done...right, finally.
Old Dec 29, 2004 | 05:48 PM
MNformula350's Avatar
I have a 96 Trans Am console in my car and all the cupholder is good for is holding my cell phone. of course i don't have food or drinks in my car.
Old Dec 29, 2004 | 07:35 PM
I actually want the single cup holder, just bescause its a little more "low pro" than having four...
Thanks for your help guys!
Old Dec 29, 2004 | 08:14 PM
85f-bird's Avatar
Engine: 2.8L, LS1
i know i'm probably being a jerk or offering opinions where none are needed, so...choose as you wish.
The 4 cup holders however are well placed in "stealth" positions. You'll probably never see the two sitting in the back, unless looking through the hatch, or over the seats...worst case it makes a nice place to put a cell if your other stuff is to cluttered. The front cupholder is only more functional because it is deeper and has a higher front wall than the previous 1 cupholder version. And the 4th cupholder is the one hidden from view under the radio pod, only showing up when needed, and in opinion...nothing looks more slick than that thing popping out on cue chix dig it.
Old Dec 29, 2004 | 08:23 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Werd! The early console cupholder is WAY to shallow to be useful. On your first hard stop when your drink dumps all over your shifter the four letter words will be flying! The other issue is the early console is very flimsy, the later console is nice and sturdy as the plastic is much thicker. I had an early console first and then switched to the later, so I have used both, and the later one is hands down the best. JMHO though!
Old Jan 1, 2005 | 10:32 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
in case ya dont knwo what it looks like. 2 of the cup holders are for rear passengers one is located right behind the shifter and the 4th swings out from the right side and when its not open you wouldnt even know it is a cup holder. And the two front ones work quite well.
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
