Weatherstripping for A/C delete box
Old Dec 27, 2004 | 08:17 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hey guys i just got my A/C delete heater box and well it has a little rust on it so i figured that ill either sand it down or sandblast it or something and was woundering about the little weather stripping on the back. where can i get a new one to replace the one thats on there since im goin to get it powdercoated inside and out?
Old Dec 27, 2004 | 08:33 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I went to walmart and got this foam weather stripping that is used for like around windows during cold weather. It had double sidded tape on it. Worked fine for me and was cheap.
Old Dec 28, 2004 | 06:11 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
just throw some silicone on there, works fine.
Old Dec 28, 2004 | 09:48 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
thats what i was thinkin of doin. if i cant find anything close to the weatherstripping thats on there now ill just put abead of black silicone on there.
Old Dec 29, 2004 | 07:33 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
I wouldn't recommend the silicone unless you're certain you can get it in place in one shot. I had to remove mine several times before I got it to sit properly. I even had to use the hammer on the lower right corner to allow it to fit with my Edelbrock headers. I used weatherstriping from Lowe's made for sealing camper shells on pickup beds. It's thin and works very well.
Old Dec 29, 2004 | 05:58 PM
Charged350's Avatar
Car: 87 IROC Z28
You test fit it and make sure its sittin to your liking, smear some silicone on there and your done, bolt it up and clean off any acces with a rag and some thinners, thats all.
Old Dec 29, 2004 | 06:19 PM
Abubaca's Avatar
I'm not saying that it's a bad idea, but why do you need weatherstripping or silicone at all? It's not like you need a perfect seal. Mine sits visibly flush, but I'm sure it's not airtight.
Now if it actually had bent edges and you stick a finger under it, then yeah, that's a different story.
Old Dec 30, 2004 | 02:58 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
well i think i might go look around home depot to see if they have some stuff that matches whats on there. if so then ill go that route. makes more sence to me and plus i want it to seal good.
Old Jan 1, 2005 | 12:32 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
frost king brand
1" wide 3/8" thick
rubber/foam weather stripping
its the best and most durable
use it for everything.
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
buckshot63
Sep 10, 2015 09:15 AM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
