Convert 91-92 front end to 85-90 TA
Old Jan 3, 2005 | 04:29 PM
1989Firebird/TA's Avatar
I'm guessing that this has been asked before and I apologize, but I need a little help. I'm thinking about buying a '91 Formula with ground effects. I don't like the banshee looking nose of these year cars, and was wondering if it is possible (and preferably easy) to pull that front end off and replace it with a 85-90 TA front end. Has anybody done this and other than the front end itself, what do I have to get (parking lights, new fogs, etc.)
Thanks.
Old Jan 3, 2005 | 08:15 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
There was a local guy with a 92 TA vert who did the whole swap, I can't remember his user name though. IIRC he posted the car for sale some time ago.
Old Jan 4, 2005 | 01:54 PM
joetiger98's Avatar
Car: 89' Trans Am KARR Rep.
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 3.27 Posi Disk
I have done this to my T/A only I put the 91' Nose on my 89' T/A, You'll need the Impact absorber assembly, Nose & upper support & the Turn signal housings & the bulb socket, & driving lights if it has any.....it's farly simple, but time consuming. Remove the front nose & upper support bar then the impact absorber. Cut the Tun signal sockets & add the other sockets(might need to add wire for them to reach, then just install the impact abrorber. Add the Nose support Then install the nose & then the turn signals......The Nose has four bolts on the sides, the impact absorber has 4 bolts on each side & the upper support is held on by bolts up top. Hope this helps.
Joe
Old Jan 5, 2005 | 01:04 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
do u have any pictures? of after it was all done
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
