overhead console install w/o dropping headlliner
Old Jan 7, 2005 | 10:45 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
overhead console install w/o dropping headlliner ??
Anyone install the overhead console WITHOUT dropping the headliner?
Old Jan 10, 2005 | 05:10 PM
Car: 91RS_92Z28
Engine: 5.0_5.7
Nobody has done this?
Old Jan 10, 2005 | 06:45 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i havent done it, but it can be done if you make the cutouts carefully
Old Jan 10, 2005 | 10:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Yes ive done it,but my car already had the O.H.Though i believe ALL F-bodys have the holes for the mounts that screw onto the roof.These hold the O.H. up.You should be able to do this.Just dont over cut the headliner.When i redid mine i made the cut outs after mounting the headliner.I cut small round holes to match the mounting points on the O.H..From there i carefully cut away material until i could install the O.H.,BUT i stayed 1.5in inward from the edges of the O.H console.
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Firebird sweden
Aug 16, 2015 05:02 PM
TheJoeY88
Aug 13, 2015 06:51 PM
bryan623
Aug 10, 2015 11:33 AM
