T-Top Care
Old Jan 20, 2005 | 12:33 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
T-Top Care
What do I need to do to ensure my T-Tops will have a long healthy life? and is there anyway to get it to stop hissing from the front when I go down the highway? if you need any more info, just ask.
thanks for the help
Old Jan 21, 2005 | 08:46 AM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
T-Tops
Rebelracer,
I've never owned a car with T-Tops.
If I did own one I would use the protective T-top covers to protect them while off the car. To stop the Hissing noise you describe you probably need to replace the weather stripping around the tops. This is a very good idea as if you are hearing the hiss of the wind, water leakage is probably not far behind. There are many sources for the weatherstripping. If you look at the top of this page there is a banner ad for Hawks, they carry these. After replacing the weatherstripping you should occasinally treat it with a rubber protectant.
Speedy
Old Jan 22, 2005 | 11:52 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I have heard people say there is an adjustment in the latch holes on the body of the car. I ahve been lucky and have never had to fool with mine! To condition the seals I have used Black Magic thick silicone gel since I got the car in 89!
Old Feb 8, 2005 | 12:15 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
thanks for the help. I need to replace my weather striping, its getting hard and crusty.
Kyle
Old Feb 8, 2005 | 07:09 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
True! There are two screws holding each of the four latch holes in place. Loosen them, and move it around a little, tighten it a little and try to see how the t-tops fit until you're satisfied, and then tighten them up. 5 minute job.
Old Feb 9, 2005 | 12:15 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Use Vasoline on the seals.
Old Feb 9, 2005 | 12:22 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
DOH.
petroleum jelly (vasoline) causes rubber to deteriorate.
Old Feb 9, 2005 | 12:30 PM
Originally posted by ES87iroc
DOH.
Gee Then why do they use it on milti million dollar PLANES ???????????????? My husband is in the Military & thats what they use on the big Jets.
I have used it on my t-tops (gee all my camaros are t-topped all 4 of them) for 4-6yrs now & Have not had a problem once?????
InfernalVortex
Apr 20, 2021 11:31 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Lbibb
May 5, 2016 12:00 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
