extend heater controls?
Old Jan 20, 2005 | 06:43 PM
Kandied91z's Avatar
i deleted my a/c along time ago but i'm getting ready to start on my custom console and i want to move my heater controls a good 3' from where they are now. has anyone had any success in moving/relocating. just looking for tips/things to watch out for as i get ready to jump in.
Old Jan 20, 2005 | 10:02 PM
pskel350's Avatar
the vaccum lines wont be a problem jeff. the cables for the mode doors will be the hard part.
make sure you let me know how you do it, since i dont like my 4th gen dash at all and want something new
Old Jan 20, 2005 | 10:24 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Due to the fact the hot/cold door in the ducting requires minimal effort to move, you could use the brake cable off a Huffy if you wanted (or a cut to fit one).
Braze or solder the cut ends to keep them from fraying.
If you want an OEM cable though, the s-10 trucks (like 90ish... had the HVAC control on the side of the cluster) use a cable about 2' longer than what's in the 3rdgen. It's long enough to reach the console if the operation of the door doesn't have to be reversed from the controls (which is vague in saying but, would be worse if I tried to explain right now)
Old Jan 21, 2005 | 02:09 AM
Kandied91z's Avatar
so are you saying in english basically extend the cable and hoses and it could be done?
i'd like to add a completely different pannel but i'm thinking that might not fit the car so i want to hide the pannel in my center console basically extending it at least 2 feet or more. i do not have air so that isn't a concern but i definately want heat for those fall nights.
keep the ideas and suggestions coming please as i'm going to get started on this next week and want a pretty good idea of what i'm getting into.
Old Jan 21, 2005 | 04:08 PM
deadbird's Avatar
Engine: TPI 305/ v6
In non-drunkenese, yes
I used the vacuum hose coupler from the Lumina I pulled my panel from. I used it (cut 1' extra hose attached to it as well) to extend my hoses and join it to the 4thgen vac. selector.
The hot/cold selector on a 4tgen control works opposite the 3rdgen so, I got the longer cable to pull the flap (door) from the opposite side that the OEM pulls from.
Old Jan 22, 2005 | 04:36 PM
Kandied91z's Avatar
i see, i'll have to look into it more then. thank you.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Formula8r89
Sep 22, 2015 04:24 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
