Hood Pins - Cutting the Hood?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey, just a question for you guys with fibreglass hoods, and are using hood pins.
I got a set of hoodpins for my b-day a few days ago, and I have a factory fibreglass hood that I want to install them onto.
My question is... is there a 'right' and 'wrong' way to drill out a fibreglass hood, so that it doesn't fray or crack around the hole when you are drilling it? I haven't done this before, so its a new thing for me. I really don't want to crack this hood, and I want to do it right.
Car: 89 Firebird
when i put mine on i just put some masking tape over both sides i was drilling. then used a small starter bit (1/16") to get the hole exactly where i wanted it and just kept steping up the bits 1/16", 5/32", 1/4", 3/8" and the last drill I used was just under 1/2" so I could use a deburing bit to take out the last little bit and clean up the edges. ended up with a nice 1/2" hole
it may have taken a little longer then some people would have liked but i really didn't want to mess up my 2 hour fresh out of the box cervins hood. it still bothers me to start cutting/drilling into new parts...
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Also should note-use a dull drill bit. A new sharp one will grab onto the glass and want to take out chunks!! Drill on a fast rpm setting as well and use light pressure. All these things will keep the bit from grabbing onto your hood and tearing it to peices.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
