Who here is running the factory plastic hood from the early third gens? Pics?
Old Feb 23, 2005 | 09:17 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am getting ready to get a hood for my car. I was thinking about a Jongbloed hood, but the local junk yard has a 'glass hood on an 83 or 84 crossfire car, I can get for 30 bucks.
Just wondering how it will look, anyone have pics?
Old Feb 23, 2005 | 09:22 PM
johnyIROC's Avatar
Re: Who here is running the factory plastic hood from the early third gens? Pics?
I had one on my '83.... I hated the ducts at first.. but then I made them functional with some home-made screens and I loved it.
Old Feb 24, 2005 | 06:18 AM
CrazyHawaiian's Avatar
Car: too many ...
I got one, but no pics sorry. I'm gonna run it on my IROC. Right now its sitting on a gutted RS.
Old Feb 24, 2005 | 07:30 AM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
i luv the stock hood, its cheap, and helps with performance plus with a bit of custom work u got a nice ram air setup.
Attached Thumbnails Who here is running the factory plastic hood from the early third gens? Pics?-top-sidehood.jpg
Old Feb 24, 2005 | 10:19 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I have a question: are they in anyway reinforced so it doesn't crumple in an accident? I wanted to get one but I don't want my knees to be the first thing that stops whatever I hit.
Old Feb 24, 2005 | 06:41 PM
Car: too many ...
I'm pretty sure the SMC material will break away like fiberglass.
Old Feb 24, 2005 | 09:15 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
does anyone know where i could get one from besides a junk yard ?
Old Feb 24, 2005 | 11:09 PM
johnyIROC's Avatar
It really is fiberglass.... I cut out my ducts and the material is almost identical to fiberglass. I did hear from someone (probably BS) that they stopped using them because there were cases of the top piece separating from the bottom piece at high speeds.
Old Feb 25, 2005 | 02:46 AM
Car: too many ...
Yup, very close to fiberglass. When I got my SMC hood (came on my 89 IROC-Z when I bought it) it appears someone had drilled holes on the drivers side by the windshield to mount external guages, and then it looks like someone else used a surfboard fiberglass repair kit or something to patch the holes! Crazyness!! hahahaha.
Only place I know of to get em is used or at the yard. I dunno what year/car my hood came from, but its definately a SMC hood.
Hey Johny, what did you use to cut out the vents? I've been thinking about doing that as well, wasnt sure what tool to use.
Old Feb 25, 2005 | 03:49 PM
Car: 1971 Camaro
Engine: 427
Thanks to all for the replys. I went ahead and bit the bullet though, ordered a Jongbloed Hood from G&T.
Old Feb 25, 2005 | 10:08 PM
Greg99LS1's Avatar
Car: 2012 Corvette Grand Sport 'vert
Engine: LS3
Transmission: 6L80
Axle/Gears: 2:73
I did mine back in '84 or so...I used a drill (1/8" bit) at the corners to get clean-radiused corners, then a dremel tool with a fiberglass-reinforced cutoff wheel to connect the drilled holes, finishing up using round and flat files to clean up the cuts for a very uniform appearance.
I left about 1/16 of an inch at the top & bottom to serve as mounting ledges in case I ever wanted to put the fake doors back on, using silicone sealer as an adhesive...
Old Feb 25, 2005 | 11:09 PM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
Yeah, it cuts pretty much like fiberglass. The hood on the turbo car in my sig is a factory "glass" one. I cut a hole in it originally for the air cleaner when it was N/A and opened it up a little more for the carb hat. I used a cutoff wheel, a file, and 80 grit sandpaper to cut and shape it. If they peel off at high speeds we sure haven't seen it, and I know we've had the car over 150 on a few occasions...
Attached Thumbnails Who here is running the factory plastic hood from the early third gens? Pics?-c-documents-settings-matt
Old Feb 26, 2005 | 10:32 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Sorry for the threadjack here, but I love your rims chevyrumble38....what are they and were'd you get 'em?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 6, 2015 09:03 AM
