Found rust on the iroc
Old Feb 25, 2005 | 01:14 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
Tonight when I was adjusting my ttops, I pulled the headliner down behind the ttops, and noticed some rust in the metal underneath the roof. How should I go about fixing it? The rest of the car is rust free.
Old Feb 25, 2005 | 04:27 AM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
If it were me i'd go nuts and take the entire car to metal and reshoot it, unfortuantely for my bank account i am a perfectionist.
I'd sand it down to metal, acid etch prime it and get some duplicolor or some sort of factory touch up for it!Sounds like its pretty minor so it shouldnt be a big issue
Old Feb 25, 2005 | 03:51 PM
Car: 91 Silverado
I think I'm going to do it. Can I use that POR-15 stuff instead of paint, being as it is under the headliner?
Old Feb 26, 2005 | 12:01 AM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
If you use POR-15 make sure you get something to cover your interior with. I would say a outdoor tarp. I've used POR-15 many times and it DOESN'T come out of ANYTHING. Good luck!
Old Feb 26, 2005 | 12:24 PM
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
I agree,That Por-15 can be nasty...I used that "invisible glove" cream from Pep Boys on my hands/arms when I worked with it.
You still need Lacquer Thinner to clean-up anything it gets on....needless to say,even that wouldnt work on anything thats fabric
My driveway still has spots of Por-15 on it 2 years later!
Good luck...its the cats azz for what you need
Later
Steve
Old Feb 26, 2005 | 03:57 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Unless your me Havn't had good luck with that stuff. Only thing it stuck to was my clothes and . Peels and sands off my car way too easily. Also peeled off my driveway and hands fairly easily, and my hands were COMPLETEY covered in it several times and allowed to dry.
Two tricks I learned to get it off skin very easily was while its still damp spray carb cleaner or wd-40 or similar and it comes right off. And two if you get some of it on your skin and it dries either scratch if off with your nails or to peel it off in one piece by applying more to the skin so its relatively thick and allow to dry. When dry and thick enough it will just peel off.
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bjpotter
Aug 12, 2015 06:06 PM
mustangman65_79
Aug 11, 2015 03:17 PM
antares57
Aug 6, 2015 07:47 AM
