camaro headlight assembly
Old Feb 28, 2005 | 04:39 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
Transmission: TH700 R4
Axle/Gears: 3.08 drum
Does anyone know where you can buy those "cups" that are behind the headlights, the things that the 4 screws mount into? What would they be called? I ask because mine are complete rust, and it would be a shame to put those back on my camaro after just getting it painted. If I can't find a place to buy them new, I'm guessing I'll have to either go to a junkyard and look at cars w/ 4 headlight setups, or grind them down and cover them w/ some POR15, but I think that would be more trouble than it's worth to do all that. Any suggestions?
Old Mar 1, 2005 | 12:22 AM
black84z28-4spd's Avatar
its not a cup...its a whole assembly..you're gonna need to rip the front end apart to install this part
Old Mar 1, 2005 | 12:53 AM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
everything is already apart as the front bumper cover has not yet been reinstalled since I painted the car. i just need to know what the "part" is called and if I can get it aftermarket or new from somewhere. maybe i didn't explain it well. if you look at a headlight, it has two parts around it. a flat black frame that holds the headlight in with 4 screws and the other half that these 4 screws go into. the half that "cups" around the back of the headlight is what I am looking for.
Old Jul 26, 2010 | 06:31 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: camaro headlight assembly
/bump, I'm in the exact same boat as this guy was, I can't find this fraking part ANYWHERE, not even on GM official parts website..Can't find anything helpful on the forums either...this was the closest thing to an answer....
Old Jul 26, 2010 | 04:28 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
The headlight "buckets" are usually found all over junk yards, in 3rd Gens,and older GM trucks that use the same size headlights. They're always in good shape around here, east coast roads must eat them up? I could probably send you a pair for like $15 or so
Old Jul 26, 2010 | 04:31 PM
Engine: 3.8, 3.4
Yarr, though upon further inspection it might be salvageable, going to get some kerosene and a wire brush and see how well it cleans up, if it seems alright I'll paint it or otherwise coat it, same with the bezels/retainers, but those aren't rusted really, just look like crap since they're bare metal. Any suggestions on a tough corrosion resistant coating?
Old Jul 26, 2010 | 06:04 PM
z2885er's Avatar
Car: 85 Camaro
Engine: 305 LG4
Wow, my post from 5 years ago has been revived. I would put some POR-15 on them for a corrosion-resistant coating if you are looking to refinish them.
Old Jul 26, 2010 | 06:20 PM
Engine: 3.8, 3.4
Looking to be my only choice, I looked everywhere, summit, GM official parts, napa, autozone, advanced auto, and probably several I'm forgetting. But upon re-inspection I think they can be salvaged, assuming that none are worse than the one I removed, going to get some kerosene and a wire brush see what happens and go from there, if the metal seems to be intact still, that's what I'll do. Don't really want to roll the dice on finding used ones, esp without a car to drive atm..had to junk my DD, and the things are a PITA to remove.
edit: henry, just saw your reply if thats $15 for all four and they have 0-to very minimal rust I'll take you up on that, they should fit in a flat rate box, so I figure only $5 for shipping, let me know how many that's for and what kind of condition, pics would be nice if possible.
Old Jul 26, 2010 | 06:50 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I don't know if I have more than a pair, they all have pretty much the same "normal" rust, and good luck getting them in a $5 flat rate box. Yours are probably fine with a little cleaning up. I'll look around and check though, maybe I've got four
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
