Good things on Megashifter
Old Mar 1, 2005 | 02:10 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
hey,
I just read the post below mine, and it seems like every one doesn't like the megashifter but the only thing is that i just bought it, and it came in yesterday. so i am stuck w/ putting in. but the only thing is that they didn't get the consel model. any one did buy it and happy w/ install? i don't mind hacking up the consel plate, that seems to be the big problem and the t-handle coming off.
that was the est. on install also?
THANKS!
Old Mar 1, 2005 | 03:50 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
The installation is pretty straight forward.
As long as it's a new or good used megashifter you should like it. I got my 2nd hand and the first owner didn't take care of it at all... infact it would barely shift through the gears until I oiled and greased it up then worked it for 20 minutes or so.
Just make sure you loctite the handle on... that's what leads to the stripped threads and handles flying off. Mine was also stripped when I got it. I think there is a nut too so you can set the handle at the angle you like.
Also keep armorall spray away from the boot. People sometimes make the mistake of cleaning it with armorall and it eats away at the rubber. Which you can buy replacements for but there pricey.
Overall it's a good shifter upgrade from the OEM one. Did you get the console model? If not I might still have my console model installation parts around somewhere in a parts pile.
I've been fairly happy with mine. But like everything else I want to try something different eventually.
One of the best things about the design is it will work with a variety of transmissions since you can use a simple set pin to block off the gear selection on the 4th gear. So you'll have a wide ability of reuse if you decide to use another transmission, install in different vehicle, or resell it.
Old Mar 1, 2005 | 04:52 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I love my Megashifter. People who don't know anything about cars always seem to think its a stick, which is kinda cool. It wasn't too bad on the install, it was my first mod and I didn't really have too much trouble (I didn't buy the console one). I used the stock shifter cable just to make the install a little easier, and I had to cut the stopper that holds the cable in place on the shifter so it would fit. After I got it to fit, I used wire and twisted it in place really tight to make sure it wouldn't go anywhere. No problems so far.
I'm tearing out the engine from my car starting today, and doing some work to my center console and replacing my door panels, so lots of parts of my car are gonna be all opened up. If you want pictures of my install, I'd be happy to take some.
Old Mar 1, 2005 | 05:01 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Could I see a few install pics? I'm hoping to get a Megashifter after I get my Firedbird painted.
Old Mar 1, 2005 | 05:12 PM
Engine: 383 SBC
That's all the closer of ones I got... If you want more I could take some and PM to you or toss up the link here.
Old Mar 2, 2005 | 12:27 PM
yeah i started it yesterday and some today... its kinda a pain in the ***, but not to bad one qustion.. i kinda had to jimmy rig my ignation switch last year and i think it woundn't start because of that or do you need to have the neutral saftey switch hooked up to work? kinda a dumb question but wanna make sure before i drop my sterring collum.
ps. sorry for the spelling. and i am doing this whole install in the pouring rain.. so its a pain to go back and fourth under the car to adjuest the damn cable.
Old Mar 2, 2005 | 12:48 PM
Engine: 383 SBC
I hooked up my neutral safety switches. So I don't really know for sure about that.
Probably should hook up all the switches anyways. Cause if I remember right ones the reverse light switch.
Old Mar 2, 2005 | 01:44 PM
yeah.
Old Mar 2, 2005 | 04:23 PM
Engine: 383 SBC
I didn't hook up the relay suggested from radio shack. The one to change the idle in park and neutral. I think I might have eventually hook'd that up too. Be sure to share pics of your hard work!
Old Mar 2, 2005 | 07:00 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I may be wrong, but I believe the relay is for the current running through the neutral safety switch and the reverse lights. I never used a relay and it works just fine for me.
I'll take pictures with the console off tomorrow or Friday if I don't get to it today.
Old Mar 2, 2005 | 08:41 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I love my mega shifter. Never had any problems with it....I made it work with the factory cable too.
Old Mar 2, 2005 | 10:53 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have the megashifter in my car and it's ok. i'll be putting in a quarter stick shifter next i believe b/c i like that style better though with a TH350 trans.
Old Mar 3, 2005 | 04:29 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I also love my Megashifter; I never had a problem installing it, and I did wire up the Radio Shack relay as the instructions suggest. Don't put armor-all on the rubber boot tho; it'll put a million cracks in the rubber. A new one cost me $12 from Summit Racing.
Tip: Sort all the parts out by which step in the instructions they're for. I put mine in sandwich bags. That way when I came to, say, step 10, and it wanted a small E-clip, I just grabbed the bag marked "10".
It also seems that a lot of people have trouble adjusting the shift cable. If you follow the directions you'll have no trouble. It just involves a lot of getting into the car and getting out of the car and getting under the car and getting back into the car- so I think a lot of people rush thru it.
Old Mar 3, 2005 | 05:34 PM
yeah its easy if you take your time the only thing is that i am figuring out the wiring and i gotta go to radio shack.
Ghettobird52
Jul 5, 2024 11:18 PM
camaro71633
Sep 1, 2015 10:24 AM
Bob88GTA
Aug 18, 2015 03:31 PM
milk
Aug 10, 2015 06:26 PM
