how to get power windows up without motor
Old Mar 1, 2005 | 09:24 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok guys i picked up an 87 ta 305 tpi but no motor or transmission but the harness is all hacked up and column is ****ed so can i take a spare set of connectors and directly wire them to the motor from a battery or how would i do this
Old Mar 1, 2005 | 11:25 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
Assuming the motor actually works, you can run a hot wire from the battery and find a good ground spot, and touch each to one of the two connectors. If the window moves down, reverse them (or if it doesn't move at all if it is already down).
I'm assuming you just wanted a temporary solution while you look for replacement parts.
Old Mar 2, 2005 | 02:08 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Remove the window switches, the blue and brown in one and blue and tan in the other, put power and ground to each switch, if the window doesnt go up reverse the two.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
