Headlight Motor Help
Old Mar 7, 2005 | 02:19 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Anyone have a clue as to why when I turn on the headlights on my 1988 Trans Am, the motor spins but the headlights do not pop up?
I have turn the ***** by the headlights and still can not get them up. I looked all around the headlight housing and do not see anywhere it would be binding or stuck on some part of the body.
Top Down solutions repair kit did the job and happy to say both motors are working great.
Thanks All
Old Apr 2, 2005 | 09:52 PM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Usually the plastic bearings get fubar'ed I fixed both mine for <$15. You'll have to remove the motors and take them apart. It's not too difficult, maneuvering the motors out of there was a pain in the ****. Overall it took me approx 3 hrs total. Good Luck! Oh yeah, the kit comes with instructions too!
http://www.rodneydickman.com/retail.html
Old Apr 3, 2005 | 01:57 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I manufacture two kits to repair your 1987-92 Firebird headlight actuators. 207280 headlight repair kit has 3 Delrin bushings (enough to repair one headlight) and is $6.25.
209280 deluxe headlight repair kit will repair two headlights and is $20. It includes 6 Delrin bushings, new gaskets, grease and screws and nuts (in case you snap them off during the repair). Both kits include detailed illustrated instructions.
Lon Salgren
Top-Down Solutions
Old Apr 4, 2005 | 08:15 PM
ferds88gta's Avatar
Car: 88GTA
Engine: 355 stealth ram
Can anyone tell me can you switch the motor assembleys from left to right? I have an extra one but it is the wrong side.
Old Apr 4, 2005 | 09:28 PM
jokers's Avatar
Car: 86firebird/86 trans am
Engine: 2.8ho/305HO 4BB
Transmission: WC T-5/700R4
you can't switch motors from one side to the other. if you look at them carefully you'll see they have 2 different part #s
Old Apr 4, 2005 | 09:29 PM
lonsal's Avatar
I can tell you. The motors are not interchangeable and can't be made interchangeable side to side.
Lon
Old Apr 4, 2005 | 09:33 PM
ferds88gta's Avatar
Car: 88GTA
I know the assembly can't but can you take the motor iteslf out of the housing and put in the other or do the motors turn opposite of eachother. It is the motor itelf I am concerned with not the gear and the linkage and such.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
stalkier
Aug 13, 2015 12:59 PM
