Weird Buzzing Sound
Old Mar 8, 2005 | 01:08 PM
bryangeerhart's Avatar
Car: 86 IROC
Engine: 305 "H" Code
Transmission: Borg Warner T-5
Weird Buzzing Sound
86 Iroc Z, Intermittant buzzing when at idle up to about 1300 RPM, I have the T-5, I know there are some problems w/ the 700-R but I have found nothing about this on the T-5, any help appreciated... oh and none of the idiot lights are on.... thanks
Old Mar 8, 2005 | 01:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What kind of 'buzzing'? Like en electronic kinda sound? Or like a mechanical whining?
Old Mar 8, 2005 | 01:30 PM
Car: 86 IROC
Its electric and it kinda comes and goes a little, kinda hard to describe kinda like this buzzzzzzz___zzzzzz__zzz___zzzzzzzzzz_____zzzzzzzzzz____zzzzzz__zzzzzzzz
with the _____ being a silent spot
Old Mar 8, 2005 | 01:39 PM
Stevo's Avatar
Car: Pair of 92 Z28s
emergency brake button? mine rattles sometimes
Like a little ringing noise...thats happens for mine when i accerate hard
i dont know was just a thought
Old Mar 8, 2005 | 01:50 PM
Car: 86 IROC
i dont think so, just for the fact that my e-brake idiot light works, and isnt on. and it doesnt make a diff if the e-brake is on or off. also it is just from idle to about 1300rpm....
Old Mar 8, 2005 | 02:08 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Exhaust heat shield, perhaps?
Old Mar 8, 2005 | 03:11 PM
Car: 86 IROC
i dont follow you..... how would that cause a buzzing?
Old Mar 8, 2005 | 03:25 PM
sellmanb's Avatar
Car: '86 Berlinetta
Is it the same noise as when you have the door open?
Or does it sound more like some plastic panels vibrating against each other?
Old Mar 8, 2005 | 03:38 PM
Car: 86 IROC
It definately isnt a plastic sound, hadnt thought of the door sound, i think that is probably the same sound
Old Mar 8, 2005 | 06:52 PM
sellmanb's Avatar
Car: '86 Berlinetta
Does it do it while you're driving, or in park, or just all the goddamn time? lol.
If it does it all the time, then open up the door, and hold down the pins all the way and see if it still does it. If it does do it still, then trace the wires back to the ground. Make sure also that it doesnt have any intermittent connections.
I can understand how that would be annoying if it goes on all the time!
(btw, I noticed you're in Oregon, there's a local 3rd gen board if you want to check it out... www.cascadecrew.org)
Old Mar 8, 2005 | 06:58 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Wheres it coming from?Maybe you power steering pump?That bad boy like to make noise sometimes.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
